Hood not closing.... - Defender Source
Old October 4th, 2005, 07:00 PM
Rover- Girl
Guest
Posts: n/a
there is a gap ( about 1/2 inch ) after closing the hood...
I was just wondering if this is the norm, or if it is suppost to close
tight !!??
Old October 4th, 2005, 07:07 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I know what the problem is. Before you close the hood, remember to remove your purse from the top of the motor. If you leave it sitting there, the hood will not have room to shut.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old October 4th, 2005, 07:08 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
Don't drop the hood from high up. Drop it from like 3 or 4" and then put your hand on the top, jump up in the air and push it closed on the way down. It should latch at the bottom.
That's one thing I have figured out. It will save the latch, etc.
Have fun!
Old October 4th, 2005, 11:06 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
Also, if the hood release cable is all gummed up with mud, debris, etc. it will stick open and the hood will not latch down all the way. Usually if you spray a little WD-40 or the like on it, it will loosen up a bit.
Also make sure that that hood release handle in the cab is pushed back in all the way so that it pushes the cable back to where it's supposed to be.
Old October 4th, 2005, 11:17 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Could also be the bumpers need adjustment. Though I do see a minor gap a lot of the time on most defenders.
-Hans
My oil line fix
My 100k stopped odometer fix
Old October 5th, 2005, 01:23 AM
It is normal. I adjusted mine up for a bigger gap to let more heat out. If it is latching up front, ie.....you have to pull the bonnet release handle inside the truck,fogedaboudit!
Old October 5th, 2005, 08:32 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
I about fell out of my chair on that one...
You made my morning, and for that I owe you a beer.
N
Old October 5th, 2005, 09:32 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I've got atleast a half inch gap on my hood. I wouldn't worry about it.
Jimmy Buffett
Old October 5th, 2005, 09:34 AM
jimmy salmon's Avatar
jimmy salmon
jimmy salmon
94 D90 AA Yellow
mine i have to drop from about 2ft for it to close
3rd low and BOOT IT
Old October 5th, 2005, 10:07 AM
Abrooks's Avatar
Abrooks
Tony Brooks
Forget the whole halfassed operation and just do pins or latches. Makes life much easier.
Old October 5th, 2005, 10:35 AM
m.michaels
Matthew Michaels
1997 D90 SW
Agreed
I ripped out that latch cable, put a blank plug over the resulting hole, and had the whole interior rhino-lined. The hood cable never breaks, never gets gummed up, and I don't have to look at the range rover icon on the hood release . . .
The advantage of the rhino-lining is the always wet carpet stopped stinking . . .
Anyway, not being a purist I enjoy drilling holes in the various body panels.
In answer to the question: the gap is variable, depending on if I left my man purse under the hood . . .
Matt
Old October 5th, 2005, 12:01 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
I agree that the gap is variable. My hood used to close almost flush until I had the head gaskets replaced. After the service I noticed that now the hood has a much larger gap. I am guessing that when the mechanic put the hood back on he did not adjust the bumpers. He probably did that to help with airflow since the truck still overheats....
Old October 5th, 2005, 12:24 PM
I usally just latch my hood, I leave the gap for more air. the only time it gets closed is on the interstate
Old October 6th, 2005, 08:14 PM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Wow... This is a lot of great information and really makes me think of changing my latch operation around a bit. Sometimes mine sticks and I have to take one of those small 'bic' lighters and wedge it in the handle then walk around and pop it by hand.
I guess the poster didn't think any of the information was of use because there wasn't even a Thank You.
Nicholas Orros
Old October 7th, 2005, 04:20 PM
devinchi's Avatar
devinchi
Tim Brown
'95 D90 ST '99D2
Well, my hood release handle came off in my hand the other day, and was actually shocked that a replacement cable with handle is only about $15 from most suppliers (DAP, RN, AB) so I will be replacing it. and after I get some trail rash and feel better about drilling hole, I will goto hood pins.
I got your JEEP thing, now it hurts when I pee!!
Old March 24th, 2009, 02:08 AM
<search is great>
adjusted the Gap down to reasonable in about 20 minutes with the center latch adjustment (loosen large nut, then adjust with Flat screw driver, reset L/R bumpers)
nest step is to replace the fiesta (or jeep) metal kraco release with stock and run a secondary emergency release to somewhere on the Rt side for when it breaks.
95' D90 - daily driver..
Old June 7th, 2009, 09:43 AM
stnmikita's Avatar
stnmikita
1995 Defender SW
Well, I'll say thank you for the information!
As a new Defender owner this thread was very helpful. I couldn't get the hood down, read the post from CBASS, pushed in the hood release handle and it shut just fine.
Now where is my purse at?
Old June 7th, 2009, 04:53 PM
cbass's Avatar
cbass
Bradlee Duncan
Welcome to the club, and glad you got it figured out!
hood
Spare tire hood mount bd90 Defender Technical Discussions 15 November 12th, 2017 11:36 AM
hood release joeoftherock Defender Technical Discussions 19 December 15th, 2012 06:47 AM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
Spare Tire mount on hood Viper-25 Defender Technical Discussions 20 July 24th, 2005 10:36 AM
SS hood bolts Campbell Defender Technical Discussions 5 December 1st, 2003 06:33 PM
