Hood Cable - Defender Source
Old March 30th, 2009, 02:44 PM
bjf's Avatar
bjf
barry f
94 ST #395
Hood Cable
I bought a new hood cable for my 110. The handle broke on my old one. It still works but I have to use pliars to grab whats left of the handle. Anyway I bought a new one and it comes with the cable and housing. Do I have to replace everything? Would it be easier and is it possible to just pull the cable out of the housing?
Basically I want to know how to do it
thanks
Old March 31st, 2009, 05:58 PM
bjf's Avatar
bjf
barry f
94 ST #395
No one knows how to replace the hood cable?
Old March 31st, 2009, 06:08 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
It can't be done. You have to replace your truck.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 31st, 2009, 06:17 PM
bjf's Avatar
bjf
barry f
94 ST #395
damn it. I was afraid of that.
Old March 31st, 2009, 07:49 PM
Barry, here is what I would do
1. Look at your new cable. Can you pull the cable and handle out of the sheath? If no, then replace everything
2. Pull the plastic grill, undo the bolt that attaches the cable to the latch, go inside the vehicle and pull out the old cable
3. insert new cable/handle into the existing sheath, lubricate as necessary
4. feed end of cable into latch and tighten bolt. You may need to adjust it a bit.
I would recommend examining the existing sheathing before deciding to just replace the cable. If it's damaged, it's likely that it will cause the new cable to fail prematurely. Replacing the whole setup isn't much harder, depending on how much trouble you have feeding around the fender.
hth
charles
Old March 31st, 2009, 07:50 PM
Anyone find someplace that sells the early style without the cable? Also, anyone know if the early style will work with the NAS 110 style extended front panel?
Old April 1st, 2009, 08:35 AM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
Hood pins
Jimmy Buffett
Old April 1st, 2009, 09:11 PM
Mark McDonough's Avatar
Mark McDonough
Mark McDonough
66' IIa, 95 D 90 300 Tdi, 94,98 D1
No Hood
hood
Die hood cable die! How to convert to ROW latch? evilfij Defender Technical Discussions 4 May 29th, 2009 02:55 AM
94 d-90 Atenna and hood latch cable. CDeWan Wanted 6 September 22nd, 2008 08:00 PM
Hood Cable Baldewin For Sale - Parts 2 August 26th, 2007 01:46 PM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
Needed: Hood Release Cable NAS D90 Hans Wanted 4 August 6th, 2005 03:18 PM
