hood adjustment - Defender Source
Old July 5th, 2006, 04:15 PM
draaronr's Avatar
draaronr
Here
LR3
hood adjustment
just got my wingtops powder coated, and there isn't enough space for them to fit between hood and wingtops, at headlights there is a 1/2 inch gap, back by hinges the hood rubs on wingtops, is there an adjustment, or do hinges need to be raised(which would be a ton of work)?
Old July 5th, 2006, 05:22 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
The front edge you can adjust by bringing the fenders up and the slam panel down. There is a good bit of adjustment in the front. make sure you loosen all the connection points and then move it otherwise it will twist funny.
On the back make sure the fender is fully seated in the angle cut outs where it attaches to the bulkhead. You have to push down pretty hard while someone tightens one of the bolts to make sure they are "seated". If the sills are on you might loosen them to make sure the fender is all the way down.
Email:
Old July 6th, 2006, 08:56 PM
draaronr's Avatar
draaronr
Here
LR3
If fits fine in the back. by looks it is fully seated, the sills and all the lines match up in the back perfect. If I raise the front up to be closer, or do I drop the slam panel.. Is the hood latch adjustable I see it takes a standard screwdriver to tighten the spring. How many bolts are involved to loosen the front, by chance do you have any pics of what you are talking about. If I make the hood in the front lower, how would this fix the back where it rubs, or should I raise the front which would make more sense to me?
Old April 7th, 2007, 02:20 PM
Andrew Vick
Andrew Vick
95 D90
So, back from the grave. The front of my hood sticks up a good 1 inch compared to the back. Several people have asked me if it's shut, and it is. The limit bumpers aren't even close to touching, and you can see the spring from the front. Is there any way to adjust that? I can stick a slotted screwdriver into it, but it ain't budging. Any ideas?
Old April 7th, 2007, 05:34 PM
Jon_Winningham's Avatar
Jon_Winningham
Sterling M Archer
1995 AA Yellow NAS D90 #2986
Yes...
There is a big flat nut in there you have to lossen up first, then you can tighten the slot with your screw driver.
1995 NAS Defender 90 AA Yellow #2986: Current
2009 Range Rover Supercharged Black/Black: Current
1993 NAS Defender 110 #375/500: Sold
1995 NAS Defender 90 Soft Top Beluga Black #2556: Sold
1991 Range Rover Hunter Green: Sold
1997 NAS Defender 90 Station Wagon Portofino Red #128: Sold
1993 NAS Defender 110 Beluga Black #215/500: sold
Old April 7th, 2007, 06:30 PM
Andrew Vick
Andrew Vick
95 D90
I'll give it a shot. I saw that nut.
Old April 7th, 2007, 07:10 PM
draaronr's Avatar
draaronr
Here
LR3
mine was the fix mike said. I took it to a body shop and it looks perfect now
Old April 7th, 2007, 07:23 PM
Andrew Vick
Andrew Vick
95 D90
What is the "slam panel"?
Old April 9th, 2007, 08:40 AM
Grover's Avatar
Grover
How did you adjust the gap in the rear of the hood?
hood
Spare tire hood mount bd90 Defender Technical Discussions 15 November 12th, 2017 11:36 AM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
air meter voltage adjustment? Rod Hayward Defender Technical Discussions 4 July 24th, 2005 11:24 PM
Spare Tire mount on hood Viper-25 Defender Technical Discussions 20 July 24th, 2005 10:36 AM
