Home design 3 link system - Page 3 - Defender Source
Old November 20th, 2004, 02:41 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
"3 link system and has around 40" of wheel travel"
Man, thanks for the laugh
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 20th, 2004, 02:48 PM
UKlandyandy
Andy
'86 exmil 90, 3.9efi auto
And your point is ????
Thought about it..... and considered, to mount the hockey sticks above the axle you need to cut & weld new brackets on.
My 3 link you bolt on..... I get the cost down to say, under 500 quid.... I sell them as a kit.... no welding, you cut you existing radius arms down & use them... I make a few quid in the process.....
Now who's laughing..... me, all the way to the bank !!!!
Old November 20th, 2004, 03:14 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Man if you don't get it, I can't help you. Now what is a quid, is that a pound? Euro??
btw: my suspension has 821.52 inches of wheel travel, and a toaster.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 20th, 2004, 03:31 PM
UKlandyandy
Andy
It's a .... and I have pity on your toaster.... LOL
Ok, sensible now... explain why putting the radius arms over the axle increases travel. Is it not the same as being under it ? in that the twisting forces applied to the bushes on the axle limit travel, be it mounted above or below.
Old November 21st, 2004, 12:07 PM
I think you missed this, I asked the same question.
The arm is mounted on top of the axle for no other reason than it helps with the clearance. You can run it below. The mount is very simple but the arm is simple too. Any decent fab guy could do it. It is cast so there is a small amount that goes into welding, but not much. Simple and cheap, now I have to get back to solving my intercooler crisis!
Old November 21st, 2004, 03:51 PM
UKlandyandy
Andy
Hi Mike,
Saw that, but does it still not bind up on full travel ? or am I missing something here....
Old November 21st, 2004, 07:17 PM
redrover
Guest
Posts: n/a
Andy does the tie rod clear the forward inside surface of your boxed steel tube on full steering choc? Looks good. The reason I say this is my SG is a rectangular box. I have never looked underneath to see how the tie rod travels when going from full lf to full right. But i have noticed a rub area. jp
Old November 22nd, 2004, 12:36 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
"Saw that, but does it still not bind up on full travel ? or am I missing something here...."
I get it. Your missing the modified radius arm and mounting. Thats what is unique, not mounting it over the axle.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 22nd, 2004, 10:14 AM
UKlandyandy
Andy
Right... thought I was loosing it.... totally, what did you do to the arm & mounting ?
Old November 22nd, 2004, 11:29 AM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
What David did besides flipping the arm on top of the axle for clearence was to cut off the second (farthest out) bushing mount on the radius arm. Then he shortened the distance between the two bushing mounts and welded them up, and made a new bracket on the axle. This relieves a lot the binding issues with the suspension, and I'm assuming it causes little to no change in driveability (braking, axle steer). Just look at the pics he posted and compare the two arms.
This should be something cheap and easy to do. However, you couldn't get the clearance he got by mounting them on top of the axle, because the spring perches would be in the way.
Mike, about welding the arm. Yes it is easy to do, since the arm is cast you need to preheat the arm before you weld it up. Any decent fab shop can do this. Also it wouldn't hurt to plate it on both sides after you weld it up.
Pete
Rigless for now
1999.5 CC PSD - Tow Bus
If it looks like it works and it feels like it works...Then it works
Old November 22nd, 2004, 11:57 AM
Cool, there is a local welder who does everything! He should be able to do this.
Old November 22nd, 2004, 02:27 PM
UKlandyandy
Andy
I see (now).... didn't notice that.... Doh !!! just call me Homer..... makes perfect sense. Good idea and using the origional arms saves cost too. My only concern would be that all the stress is concentrated into the welded area and I agree that this should be plated both sides with say, 1/4" thick material to prevent a major failure.
I'll still persue the 3 link as I've already ordered the laser cut parts and I don't want to butcher my existing axle at this time, however, I can always try your way if it doesn't work out like I want it to. If people wanted to modify there axles in this way I'm sure QT Services would make some bespoke arms based on there ultra light ones if you didn't feel happy modifying the origional cast items.
Have attached a couple of pics of the radius arm plates that I've drawn up and will post some pics of the completed parts once I get them fabricated.
Thanks for the help so far.....
Old November 29th, 2004, 03:04 AM
UKlandyandy
Andy
Hi,
Just to get things straight in my own mind. The more lift you have on your rig, the longer the third link needs to be to correct the castor angle.
Correct ?
Cheers,
Andy
Old November 29th, 2004, 07:27 AM
mudrover's Avatar
mudrover
Peter Miller
1990 RR
Yes, the more you lift your truck up, the worse your castor, but don't forget you have to take into account pinion angle aswell.
Pete
Rigless for now
Old November 29th, 2004, 07:36 AM
redrover
Guest
Posts: n/a
Yep, you would need to extend center link to keep the u joint angle the same at each end and caster sim to stock. OR you could angle the pinion up and use a double cardan drive shaft. But this will deff screw the caster. JP
Old November 29th, 2004, 07:55 AM
UKlandyandy
Andy
Thanks guys.
Was just making sure I'd got it straight in my head. I can sort the 3rd link now and make it adjustable by having the mounting on the x-member seperate and bolt on (heavy duty) thus allowing it to be shimmed to set the castor. Means I can use another modified radius arm to keep the costs down.
Will use a high yolk angle prop for the front with double cardon as well.
Cheers,
Old December 4th, 2004, 08:52 AM
UKlandyandy
Andy
Hi Guys,
Have got the laser cut parts and tacked them all up now. Here are a couple of pics of the progress.
Cheers,
Andy
ID:	1986   Click image for larger version
Old December 18th, 2004, 03:54 PM
UKlandyandy
Andy
Latest pics.
Axle tube and x-member all completed. I'm just waiting for the new radius arms & 3rd link from dave at QT Services. They should be here very early in the new year.
Cheers,
Andy
ID:	2115   Click image for larger version
Old December 18th, 2004, 06:23 PM
troutrover
Christian Beck
many
Andy, looks good! What did you decide to use for your center link?
CB
Old December 19th, 2004, 09:42 AM
UKlandyandy
Andy
CB
Hi,
I'm goign to use a shortened version of the outer radius arms. This will allow me to use off the shelf poly bushes and it keeps the design simple and easy to service in the field. I'm fairly confident that I won't suffer significant changes in castor due to the bushes compressing as when there tightened up there heavily compressed already.
Cheers,
Andy
On-board shower - home built design JackW Defender Technical Discussions 3 August 16th, 2008 07:15 PM
What should I look for in speakers loykd Defender Technical Discussions 66 September 19th, 2006 10:56 AM
induction system design and mods jaherring Defender Technical Discussions 3 September 10th, 2004 08:20 PM
