Holes in body - Defender Source
Old January 22nd, 2008, 09:46 AM
kennybahr's Avatar
kennybahr
Kenny Bahr
94 D90 Alpine White #1245
Holes in body
Just underneath the v8 emblem, I've got holes, that look to be damage from rocks while offroading. I bought the truck with these holes already there. There was a land rover sticker covering the holes, I took the stickers off unfortunately, and I can't find anywhere that sells these stickers/decals. Is there any way to repair these holes? Does anyone know where I can get these stickers? Refer to the pictures below.
Kenny
ID:	11786   Click image for larger version
ID:	11788   Click image for larger version
Old January 22nd, 2008, 10:00 AM
Those holes are corrosion. You can get the rover stickers at RN or anywhere really, but fenders are cheap and easy to replace, you may as well fit a new one.
That, and check over the truck carefully, because to have holes corroded in the aluminum body work doesnt bode well for the steel parts. It might just be a bad repair or something, but I haven't seen holes like that on a truck any newer than 25 years.
Old January 22nd, 2008, 10:15 AM
kennybahr's Avatar
kennybahr
Kenny Bahr
I'm not sure it it's corrosion. It looks like damage from a rock or something. It even looks like it was drilled. If I decide to replace the fender, it is hard to match paint?
Old January 22nd, 2008, 10:19 AM
It is corrosion, there is a steel bracket behind that part of the fender.
Old January 22nd, 2008, 10:37 AM
kennybahr's Avatar
kennybahr
Kenny Bahr
So for an amateur...like myself not knowing much about bodywork, would it be easy for me to install a new panel by myself? Where would go to get the paint matched?
Old January 22nd, 2008, 10:50 AM
shawnpalmer's Avatar
shawnpalmer
Shawn Palmer
1997 SW-Arles Blue
All you have to do is go to any auto paint shop and tell them the paint code for alpine white. You can find that by searching here. The hardest part (and most expensive) will probably be getting someone to paint it for you. It will be a project, but it will be fun.
Paint Code for Alpine White: LRC456
Old January 22nd, 2008, 11:06 AM
Burke's Avatar
Burke
Burke Bell
'94 NAS D90 #158
Back to the decal (if you decide to replace). I have ovals under my V8s. They are better quality than that and have a black plastic edge to them. I bought them years ago from the dealer. If I remember, they were the same as the rear ovals on 110s.
"I race cars, play tennis, and fondle women, BUT! I have weekends off, and I am my own boss." - Arthur
Old January 22nd, 2008, 11:18 AM
You dont have to know anything about body work to replace defender panels - its all nuts and bolts. In your case, the front cage comes off, you remove the wheel arch eyebrow, undo the fender and thats that. Assembly is reverse of removal!
Corrosion on aluminum doesnt look like corrosion on steel. It tends to look like shale flaking away, and eventually you get holes.
The paint will match pretty well. With all the seams and waviness on defender panels, you dont have to have a really close match for it to look good.
Old January 22nd, 2008, 11:39 AM
If you clean out all the corrosion, you can just weld a couple patches on skim it with a little bondo and paint over it.
Old January 22nd, 2008, 11:54 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Do what Ron said.
I replaced both my outer fender skins. They took forever to get, and were expensive.
Or
Call RDS and have your bodyshop drill out the cage holes. Much Cheaper and quicker.
EwS
Old January 22nd, 2008, 11:59 AM
If PO put a sticker over that corrosion and didn't tell you about it, my radar would go off as a warning sign, and I would think a full body inspection would be in order.
POP RIVETS LOOK COOL-THE MORE THE BETTER! (just kidding...do it right)
Old January 22nd, 2008, 12:15 PM
It is common to have corrosion there. Check under the bottom seal where the rear tailgate goes, door bottoms, and near the cappings on the bed. Also, where the bulkhead and the front fenders touch and where the cage touches the fenders. Finally, the sills tend to rot where the steel brackets hold them on.
Old January 22nd, 2008, 12:33 PM
Grover's Avatar
Grover
Question
Was that a D90 from the North, i.e. exposure to road salt?
Old January 22nd, 2008, 12:43 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
Yes, the carfax said it was originally from Chicago, then Wisconsin.
Old January 22nd, 2008, 12:55 PM
Lets see pix of the underside - the rear crossmember, the outriggers etc.
There is more corrosion in those pix than just a couple holes, it looks like you've got several starting up there.
Also, those LR logos arent OEM. There are nice OEM ones available. Those are the kind of "resin pool" decals commonly for sale on ebay.
Old January 22nd, 2008, 01:25 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
Would you advise me to put a better sticker to cover the corrosion for now, as my finances will not allow a replacement fender as of now. let me know where I can get 3 new "nice OEM" stickers. I'll take a few pictures in a few minutes.
Old January 22nd, 2008, 01:35 PM
JSQ's Avatar
JSQ
Jack Quinlan
I recommend you don't put anything over the corrosion to hide it.
That way you will see it everyday and will constantly be reminded of the need to address it. It may be painful, but obscuring it could lead you down the dangerous path of deferred maintenance. If you can't fix it properly now, then suffer looking at it so that you fix it as soon as you can.
Oh, and stickers are lame.
Old January 22nd, 2008, 01:40 PM
Sure, slap some stickers on there.
A search for "decal" at Atlantic British turns up about 78 options - some of which are cool, some of which suck.
When it comes time, dont pay more than about 250 for a fender, and dont bother trying to find a NAS one, just cut holes in a normal one for the cage and side light.
Old January 22nd, 2008, 02:08 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
My truck has been in Chicago for years now and not one Birmabright panel has corrosion like that. It looks more like Ron said that someone botched a repair on the bracket behind the peice.
No other D's in the Land Rover Club have any holes on the birma from salt either. Frame maybe, but that is steel. . .
Old January 22nd, 2008, 02:37 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
Here are the pictures of the defender 90. I have all of the pictures in a photobucket account...just copy and paste the link.
http://s34.photobucket.com/albums/d1...Defender%2090/
Kenny
body
Dilling holes in aluminum body panels fenwaystan Defender Technical Discussions 1 March 22nd, 2008 01:14 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Source for long body bolts? 1/2x7.5 inch grade 8 cgalpin Defender Technical Discussions 7 March 12th, 2005 12:59 AM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
