Holes in body - Page 2 - Defender Source
Old January 22nd, 2008, 02:51 PM
Now is the time to start abating before it gets bad. Pull the rear bumper and paint the rear cross member. Pull the transmission crossmember and check for holes behind it. Replace the fuel tank skid plate. Pull the bottom seal for the tailgate and replace the screws with aluminium pop rivits. Fill the frame with waxoyl or similar. Put rubber strips behind the metal brackets. Consider replacing or painting the front shock towers. Make sure there is no built up dirt or mud anywhere on the frame.
Old January 22nd, 2008, 03:31 PM
What Ron said
Old January 22nd, 2008, 03:38 PM
What JimC said.
Old January 22nd, 2008, 07:23 PM
Grover's Avatar
Grover
What Ron and JimC said...
The middle crossmember under the tranny will trap moister between itself and the frame...it is a PITA to remove, I used the bottle jack and some wood blocks to spread the frame just enough to allow the crossmember to drop out. Grind away what rust you find and what you can't grind away, treat it with a rust arresting solvent, then paint it...
Good luck...
body
Dilling holes in aluminum body panels fenwaystan Defender Technical Discussions 1 March 22nd, 2008 01:14 PM
lifting the body (not plastic surgery :-) cbass Defender Technical Discussions 11 April 25th, 2005 12:14 PM
Source for long body bolts? 1/2x7.5 inch grade 8 cgalpin Defender Technical Discussions 7 March 12th, 2005 12:59 AM
Drilling holes for rear light guards khatadin Defender Technical Discussions 8 January 5th, 2005 08:43 PM
body work on aluminum mattdh Defender Technical Discussions 11 July 4th, 2004 02:47 PM
