Hole Tapping - Defender Source
Old July 22nd, 2008, 05:03 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
94 D90 Alpine White #1245
Hole Tapping
Does anyone have any suggestions on re-tapping the 4 holes in the bottom center of the bumper that bolts to the rear crossmember? I have drilled the holes with a 27/64 drill bit, and have a tap bit and tapper for 12 mm bolts. I just can't seem to get this going. I'm hoping someone has some advice on doing this.
Thank you in advance,
Kenny
Old July 22nd, 2008, 05:24 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
I'm assuming that is the right size hole for the 12mm tap - it will say on the side of the tap what size hole is needed. I use oil on the tap and continuously reverse directions of the tap to clear the metal shavings. Try a smaller tap on some 1/4" thick scrap to get the feel for the process.
Old July 22nd, 2008, 11:01 PM
Kenny, just to be clear, the size you tap to has to match the hole drilled (and as Chris says, the drill size will be stamped on the side of the tap). If the 12mm tap doesn't call for a 27/64 hole, you need to either
1. get the tap for a 27/64 hole
2. get a tap and drill bit for the next size bigger than 27/64 and drill them out some more.
You choice of tap should also be driven by the size and thread bolts you can buy.
Then to actually tap out the holes, you need to line up the tap as straight as you can and slowly turn it into the hole. As you make progress cutting the thread you need to back the tap out (turn anti-clockwise) and then turn clockwise again repeatedly. This cleans out the thread you just cut and makes it easier to cut more. Use oil to make the process go easier.
Oh, and be sure to wear eye protection since you'll be spending more time on you back directly under the holes with crap falling on you. Music helps. Children "helping" usually don't as you'll have a short fuse at the time.
hth
charles
D90 gas tank hole fix hlamar Defender Technical Discussions 26 May 20th, 2010 04:19 PM
WTT: 97 center console cubby tray (hole for no hole) fleabus Wanted 3 December 23rd, 2007 10:59 PM
Lifter / engine tapping... oil pressure issues.. revtor Defender Technical Discussions 10 July 12th, 2007 11:04 PM
Hole in the Rock Trip with Bill Burke Maine 110 The Vendors Loft 0 March 2nd, 2005 04:13 PM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
» Defender Registry
Red 90
SGS714
Augi
DaveGilley
Add your Defender
