Hole in my Engine Block - Defender Source
Old September 17th, 2011, 09:09 PM
punter
1966 Series IIA
I've got a question for all you smart LR guys out there...
If you look at the attached photos (of the rear of the engine) I have circled a hole in the block. This hole looks like it goes right into the water jackets. However, I do not remember anything that plugged into here. Am I missing a freeze plug, or am I forgetting about something else that goes here?
Anyone know what this is?
(The engine is a 3.5L V8)
Old September 17th, 2011, 09:16 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
No pictures?
Old September 17th, 2011, 09:19 PM
punter
1966 Series IIA
damn things wouldn't load
ID:	42065   Click image for larger version
Old September 17th, 2011, 09:32 PM
Firemanshort's Avatar
Firemanshort
David Short
1980 Stage One 109
The factory motor has a crank case vent there that has a tube on it that goes back to the intake on the CARB.
Firemanshort
1980 Stage One 109
Sterling, VA
Old September 17th, 2011, 09:38 PM
details on the engine build please. I must have some of those valve covers
Old September 17th, 2011, 09:44 PM
punter
1966 Series IIA
Believe it or not... I bought it with those valve covers on it. They were originally natural aluminum, but I had them powder coated black (but left the ribs exposed).
I do not know if those valve covers came on it from the factory or if they were an aftermarket add-on. The engine is from an '84 Defender that (I believe) came into the states through Canada. I suspect they were original, just because the engine didn't look like anyone had ever done a thing to it in its entire existence (to include oil changes) when I got it.
------ Follow up post added September 17th, 2011 09:47 PM ------
Thanks!!! I lost a lot of my photos from the tear-down in an unfortunate hard drive crash.
Old September 18th, 2011, 07:35 PM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Those valve covers come on all the carbed V8's. They dont work on EFI motors unless you can do some modifications (never tried that).
Nice looking motor dude.
Matt Browne
Old September 18th, 2011, 08:32 PM
What mods would have to be made, I know a CARBed 3.5 thats near me, I might see if it is possible.
Old September 20th, 2011, 07:11 AM
junkyddog11
oil soaked filter
95 RRC 300tdi
Never tried it but the venting system is different, nothing major I'd suppose. I know that when converting from carb to EFI I have been using the EFI valve covers but I'm not sure why. Probably just convenience and the use of std bits.
Matt Browne
engine
2003 Discovery 4.6 engine block nomadic90 Defender Technical Discussions 8 July 15th, 2010 09:43 AM
Block sealant (was coolant gasses in rad) Davis Defender Technical Discussions 6 April 6th, 2006 01:08 AM
Engine Block Heater for Defender 110 - tips? COSteve Defender Technical Discussions 10 December 6th, 2005 01:12 PM
