Hitch/ pull point install question - Defender Source
Old May 10th, 2004, 03:37 PM
JKM
John Miller
1997 D-90SW Full mods
I have a Roveraccessories drop hitch/ pull point to install. Has anyone gone through the process of dropping the fuel tank down far enough to install the bolts through the rear crossmember? If so can you share your experience??? I am in need of a bit of advise as to the process and amount of time it may take.
97 D90 SW JKM
JKM. . .The world is run by those who show up.
Old May 10th, 2004, 03:59 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
The install time will take the better part of a day. But it really depends on the condition of things like bolts, skid plate, etc. I took the time to sand and paint the rear crossmember as it was pitted.
Make sure you get a backing plate to mount to that on the inside of the crossmember. You can get one from EE. Also make sure your tank is as empty as you can make it. Don't try siphoning, their is a flap in the tank entrance that prevents getting a siphon to the bottom.
The install conceptually is straight forward. Disconnect your rear swaybar. Undo the various bolts for the rear bumper and remove. Stick a jack under the skid plate assembly to support the weight of skid plate and tank. Undo the skid plate bolts. Drop the tank. Make sure you only drop the tank about 6+ inches (the rear wiring harness does not give you much flexibility, neither does the tank fume handler in the passenger side wheel well). In addition, you can push the tank slightly forward to gain access (up to the ball joint assembly). You'll need to place the backing plate and nuts/lock washers/washers on sight unseen. It's not easy, but not impossible. Once done, reverse the order of disassembly.
If you do go with a backing plate. You'll need longer bolts that those supplied with the kit. I don't remember what I used. But get an assortment of lengths. Just return the unused ones. You want to make sure the bolts do not stick out past the rear crossmember. Otherwise they will spear the gas tank.
Have fun!
Old May 17th, 2004, 10:17 PM
JKM
John Miller
Thanks Dave- all went well.
JKM
Old May 18th, 2004, 08:39 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
No sweat John. Glad to be of help. I assume everything turned out okay?
hitch
Gas Tank Skid plate install on a D90 - question... pmd Defender Technical Discussions 17 December 19th, 2011 04:04 PM
Center seat install question brn24whl Defender Technical Discussions 7 October 9th, 2009 11:37 AM
Fiberglass top install question d90_1372 Defender Technical Discussions 7 September 14th, 2009 11:07 PM
Bilstein Install Question 48vphantom Defender Technical Discussions 7 September 18th, 2006 04:08 PM
Mantec Snorkel Install Question ronward Defender Technical Discussions 2 April 1st, 2005 08:16 AM
