Hit brakes, lose speedometer - Defender Source
Old March 11th, 2012, 06:37 PM
This problem seemed to spring up today. When I hit that brakes, the speedometer dies. Release the brake pedal speedo comes right back.
Any ideas?
Old March 11th, 2012, 06:42 PM
Im assuming you have an electronic speedo?
Old March 11th, 2012, 06:57 PM
Correct, electronic speedo.
Old March 11th, 2012, 07:06 PM
RedD90's Avatar
RedD90
JNH
'97 D90
I've not experienced the loss of the speedo reading but I do encounter other speedo-related problems which are well-documented over at ECR. My problem is losing the mileage reading which although ECR used to be able to fix by taking the unit out and doing some tweaks/cleaning the connections etc, they've since abandoned this due to extra costs and now recommend sending it to an LA-based firm (whose name escapes me - sorry).
Hicktonite
Old March 11th, 2012, 07:32 PM
The loss only at braking would lead me to think its a connection somewhere rather than some sort of unit failure. Or is that not necessarily correct?
Old March 11th, 2012, 07:49 PM
Dude this has to be due to the solar flare or something. 3 crazy electrical faults on the forum in a single day? That just makes no sense.
http://www.defendersource.com/forum/...ad.php?t=36425
Old March 11th, 2012, 08:23 PM
RedD90's Avatar
RedD90
JNH
'97 D90
Ha ha! Voodoo, Witchcraft, Mayan Solar Flares!
Hicktonite
Old March 11th, 2012, 08:49 PM
Jesus, it's a goucher:
http://www.defendersource.com/forum/...ad.php?t=36424
Old March 13th, 2012, 12:05 PM
bump....seriously, I'm the only dude that's had this issue ?
Old March 13th, 2012, 04:07 PM
You had Pedro in your truck on Sunday. Just saying...
Originally Posted by pendy
I'm here for the D's
brake, speedo
VDO Speedometer Parts/Installation/Problems Merged Threads redrover Smaller Projects 86 March 7th, 2008 10:20 PM
Correcting speedometer after lift/tires Seriesman Defender Technical Discussions 16 November 24th, 2005 08:37 PM
?????? jimmy salmon Defender Technical Discussions 8 October 13th, 2005 11:54 AM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
