hinges? - Defender Source
Old March 28th, 2010, 03:18 PM
beachrover
97 hard top
hinges?
my d90 is in the body shop getting sprayed, the guy says he got the doors off the body but cant get the hinges off the body is there a nut on the inside? any tricks to fix this without heat?
Old March 28th, 2010, 04:56 PM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Hinges are just bolted to the bulkhead. Likely they have bonded to the surface of the bulkhead via rust, judging from your username.
Old March 28th, 2010, 08:57 PM
isleofbones's Avatar
isleofbones
Mike Deery
1984 D-90
Hinges are bolted to the bulkhead by way of captive nuts(nuts that sit inside a steel clip that slides onto the bulkhead. Often the nuts sieze up and the clips holding them disintegrate. If you are going to the trouble of removing the doors for a respray, it seems like you are going for a nice job as opposed to an economy painting. That being said, you might want to consider a new set of hinges and mounting nuts/bolts. They are fairly cheap; but don't go for the cheapest ones. I got mine from Safari Rovers when I did a repaint and was very happy with the quality. They have nylon inserts to combat corrosion. Anyway, your body shop can simply drill out the old bolts if he can't get them out. Taking the old hinges out will also give you a chance to spray some waxoyl cavity spray into the bulkhead/vent area and get an idea if corrosion has taken hold in there. I had to drill out one bolt. Good luck.
Old March 28th, 2010, 11:35 PM
Impact screwdriver and large hammer make short work of stuck bolts screws ...
Stainless Defender Door Hinges Chaucer For Sale - Parts 7 August 19th, 2005 11:04 AM
updated Defender hinges eric_besore Wanted 3 May 15th, 2005 10:03 PM
hinges dmarchand Misc. Chit-Chat 62 December 23rd, 2004 10:02 AM
Rear Hinges - Original setup Image please Kimos Defender Technical Discussions 13 November 1st, 2004 06:17 PM
Part #'s for new non-corrosive hinges Chris Cox Defender Technical Discussions 7 May 26th, 2004 09:50 PM
