Hinged fog lights. - Defender Source
Old February 28th, 2005, 09:06 PM
rustydefender
Russell Newton
97 D-90 sw
Hinged fog lights.
I want to put some off road lights up top. I like the way the lights on the rover in the background are hinged how do you do that? And where do you run the wires? can you keep them unexposed? And finally what kind of lights do you guys run because most companies don't mention candlepower so I really don't know which lights to pick. Does anybody have some good picks on wiring lights?
Old February 28th, 2005, 09:23 PM
I think those are the Hella 3k, they will hinge back because of the way the mount is, I dont think the 4k will do that due to the newer mounting setup.
Old February 28th, 2005, 09:33 PM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
If you want to hide the wires you will have to drill into your roll bar and run the wire through that. You will probably have to unbolt it at the fender as well and drill that end too. I'm pretty sure the bar is welded with a cap. You wont have to drill the body as there is a big hole from the roll bar. The light will come "hinged", they are made to be adjustable, you can tip them back with simple tools or you can try adding a wing nut or some other type of fitting to make it tool less.
ht, lights
Fog Lights lynchee Defender Technical Discussions 1 October 29th, 2006 09:32 AM
fog lights in the bumper? pfmbf Misc. Chit-Chat 1 June 21st, 2006 09:18 AM
Fog lights Campbell Defender Technical Discussions 1 May 17th, 2004 01:11 PM
Hella fog lights PT94D90 Defender Technical Discussions 1 February 4th, 2004 07:45 PM
Hella 4000 lights Nigel Buchan For Sale - Parts 4 November 26th, 2003 09:47 PM
