hinge replacements - Defender Source
Old April 3rd, 2006, 10:44 AM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
hinge replacements
Hey, I tried looking and searching the site but could not find anything but the standard replacement hinges. I am afraid these will just rust like my the current ones, so I was looking for a more rust proof solution. Is there a place to get them? Or is there something I can do to the stock hinges to prevent the rusting?
thanks,
Bil
Bill
Old April 3rd, 2006, 11:01 AM
btate
Bryan Tate
d90
Atlantic British has a $500 set of aluminum hinges
Old April 3rd, 2006, 01:52 PM
Troys
Troy Smith
1995 D90 SW
Bryan;
MUD UK has a stainless steel hinge. I have them on my truck. I would be happy to shoot you some photos. Have been meaning to post here bu the photos are to big. Do a search under the For Sale section. I bought them from a guy here selling them.
e-mail me at tsmith@smithpackett.com if you wnat to see them on my truck.
Troy
Old April 3rd, 2006, 02:19 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
RN has a set that has different bushes. They are pricey but after a year no rust. Add the Mud UK stainless kit and your done.
EwS
Old April 3rd, 2006, 05:10 PM
artm
Arthur Maravelis
97 SW
For the adventurous one...take your current hinges and grind them down to accept one or two (top and bottom) high density polypropolene washers. There's a certain kind of plastic designed for this application and I believe the replacement hinges simply have such washers.
I used the material in sheet form between the spring leaves in my Series 3 in the hopes of getting less rust and smoother operation. In the end, more trouble than they were worth but in this applicaiton it's worth a shot.
Old April 11th, 2006, 04:43 PM
kolvedic's Avatar
kolvedic
Bill Lewis
EwS
I looked at the RN site and couldn't find these? Looks like the PO already installed the stainless bolt kit.
thanks,
Bill
Old April 11th, 2006, 04:51 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
Bill - I, too, have a set of alloy hinges from RN. Just call them and they can give you the details and a price. They weren't cheap but after 6 months no hint of rust. I also have the MUD UK stainless hardware. Mark
Old April 11th, 2006, 11:23 PM
johare
Jay
95 D90 White ST
I just got these hinges from RN as well. They come ready to be painted - my guy here quoted me $125 to paint them so figure that in with the cost ~$267 with shipping.
Old April 12th, 2006, 10:47 AM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Wow, that is pricey. Isa that paint and installation as well? I got the hindges painted with sikkens base and clear and installed as well as having several areas touched up as well...
EwS
Old April 12th, 2006, 11:26 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
Just get a rattle can of matched paint from RN and paint them (after priming) yourself.
Old April 12th, 2006, 12:31 PM
artm
Arthur Maravelis
97 SW
No shit! $125 to paint hinges? Are you nuts paying that? I know they're nuts charging it.
Seriously, do the plastic washer bit I mentioned.
Old April 12th, 2006, 02:16 PM
kolvedic's Avatar
kolvedic
Bill Lewis
Guess I am not sure about the nylon washer bit, I thought it was the steel hinge pin that caused the rusting?
BTW, I just tried to order paint from RN but was told they no longer carry it in spray cans? I ended up ordering from paintscratch.com (sp?)
Bill
Old April 12th, 2006, 02:45 PM
artm
Arthur Maravelis
97 SW
I think the rusting occurs when the weight of the door grinds on the part of the hinge attached to the body (not the door). I recall seeing in the new design a plastic washer on the bottom, preventing the two halves from grinding.The washer was 1mm at most.
Old April 12th, 2006, 04:56 PM
roverboy's Avatar
roverboy
Thomas
Booger
Ebay. They are all over ebay from the UK. And they're not that expensive.
"There is absolutely no excuse for the way I'm about to act."
Old April 13th, 2006, 09:11 AM
johare
Jay
95 D90 White ST
I'm exploring other options as $125 is a lot to pay but apparently in order to get the color right they have to mix a minimum of a quart which costs ~$60. The 125 includes clear coat as well.
Old April 13th, 2006, 09:30 AM
roverboy's Avatar
roverboy
Thomas
Booger
I don't know what color you need, but I have a quart of Alpine white that is ready to spray here that I'll sell you. It's a mix that doesn't require a clear coat. I don't have a white truck any more so I no longer need it.
Old April 13th, 2006, 11:23 AM
johare
Jay
95 D90 White ST
I neeed Apline white - That would be great. I'll shoot you an email.
ac
Door Hinge Options... CDN38 Defender Technical Discussions 2 February 4th, 2005 12:29 PM
Door hinge issues JBurt Defender Technical Discussions 4 January 31st, 2005 05:00 PM
Door Hinge Nut Jeff 95/126 Defender Technical Discussions 2 January 14th, 2005 11:05 AM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
Door hinge pin mspell Defender Technical Discussions 1 September 8th, 2004 04:14 PM
