Hinge replacement questions? - Defender Source
Old December 7th, 2014, 12:19 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
I'm going to be installing new Td5 hinges and hardware soon. I'm wondering what the preferred anti seize is? Also, are the bolts #4 phillips or Torx? If Torx, what size?
Thanks in advance.
Old December 7th, 2014, 12:54 PM
Go stainless steel for sure. As for anti seize I used this:
Old December 7th, 2014, 01:41 PM
The existing bolts are posi drive as Jeff said. I wouldn't re-use the the originals. Replacements come in all variety's including torx and allen as well as phillips. I use copper anti seize.
I have drilled the heads off dozens of frozen door hinge bolts so make certain you do use new hardware and use anti sieze.
Old December 7th, 2014, 04:09 PM
I think Mylar washers between screw and hinge would help too for avoiding to remove paint when tightening down.
Old December 7th, 2014, 08:46 PM
Vunkle's Avatar
Vunkle
Virgil Broussard
1997 defender 90
Thanks for the advice.
ac
Door and rear hatch hinge replacement wmatos1001 Smaller Projects 13 September 11th, 2014 08:03 PM
Rear Swing Gate Hinge Bolt replacement LandWorks Defender Technical Discussions 4 September 9th, 2010 06:52 PM
Spare Tire Hinge Replacement PDX Bolt Defender Technical Discussions 9 July 19th, 2010 08:18 PM
Transmission replacement questions cgalpin Defender Technical Discussions 1 August 1st, 2006 12:16 AM
Rear Door Hinge Replacement Rob Defender Technical Discussions 2 January 21st, 2004 01:26 PM
