Hinge Direction HELP! ASAP! - Defender Source
Old April 10th, 2012, 09:48 PM
Rosproline157's Avatar
Rosproline157
Matt Oaks
1992 Defender 90
I have a new set of hinges (old style). Could someone please tell me if the thick side of the hinge of goes up or down. Or the below parts numbers are left or right sides? Thanks!
part #mrc2019b
part #mrc2018b
Old April 10th, 2012, 09:52 PM
http://www.rimmerbros.co.uk/Item--i-GRID010598
Old April 10th, 2012, 09:57 PM
Thick on the bottom. Should look obvious once you put them in place.
Originally Posted by pendy
I'm here for the D's
Old April 10th, 2012, 09:59 PM
Rosproline157
Matt Oaks
1992 Defender 90
The part numbers I listed are stamped on the interior of the part. I do not have the actual numbers.
------ Follow up post added April 10th, 2012 10:00 PM ------
Originally Posted by cgalpin View Post
thick on the bottom. Should look obvious once you put them in place.
thank you!!!!!!!!!!!!!!!!!!!!!
new style door hinge $ mattdh Defender Technical Discussions 2 December 4th, 2005 01:27 AM
Door Hinge Options... CDN38 Defender Technical Discussions 2 February 4th, 2005 12:29 PM
Door hinge screw replacements - guidance paulb Defender Technical Discussions 4 September 22nd, 2004 06:51 AM
Door hinge pin mspell Defender Technical Discussions 1 September 8th, 2004 04:14 PM
Air Conditioner Vents on NAS 110 - How to hold direction of flow? COSteve Defender Technical Discussions 5 July 15th, 2004 11:11 AM
