higher wattage bulbs - Defender Source
Old August 20th, 2008, 09:02 PM
Do you think the stock wiring harness could live with 65/70 watt bulbs?
Old August 20th, 2008, 10:45 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
I wouldn't chance it. It has enough trouble with stock bulbs sometimes, particularly the switch. Throw a relay in there.
-Hans
My oil line fix
My 100k stopped odometer fix
Old August 21st, 2008, 08:49 AM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
-Hans
x2! Besides, if you do it right, you get the added benefit of MORE light output, since the bulbs actually get more voltage..
~Scott T.
'95 D-90 ST - AA Yellow
Old August 21st, 2008, 11:01 AM
When I installed relays and higher wattage bulbs, I measured voltage loss from the battery to the lights.
Stock lights, 55/60 Amp, stock wiring, 13% voltage loss low beam and 18% high beam. Thats 1.6 and 2.2 volt loss....
Stock lights, 55/60 Amp, upgraded wiring and relays, 2% and 2%.
Hella ecodes, 80/100 Amp, upgraded wiring and relays, 3% and 4%.
Old August 21st, 2008, 03:47 PM
CDeWan
Clay DeWan
5.3L beastie
I ran PIAA super whites without problem using the stock switch. But I agree with everyone that you should run a seperate harness. I went on ebay and purchased and H4 wiring harness for about $27.00 and installed it. Easy to do as I ran the power wire off of the starter motor. Now it is only stock current or less running through the original harness just to activate the 2 relays for the lights. I can email you pics or walk you through the install of the H4 harness.
led replacement bulbs for dash gauges Marc Weinstein Defender Technical Discussions 75 October 21st, 2017 03:52 AM
dash bulbs shawnpalmer Defender Technical Discussions 8 February 20th, 2011 12:56 PM
Where to find bulbs TND90 Defender Technical Discussions 2 March 11th, 2006 10:18 PM
weird noise with higher rpm scubadanster Defender Technical Discussions 8 December 13th, 2004 07:32 PM
colored Christmas bulbs Bowtracer Defender Technical Discussions 5 October 22nd, 2004 10:54 AM
