High voltage - Defender Source
Old September 9th, 2014, 10:57 AM
atpick's Avatar
atpick
Andy
1990 110
High voltage
Ok, looks like I have a second project in as many days....symptom is when I am driving at high rpms, the battery gauge reads high. If I drive around base at slow speeds and lower rpms, it reads normal. The PO said the battery was dead before I bought it because he hadn't driven it in 5 months. He had it charged by a mechanic and they said it was fine. The two pictures show the gauge after high rpm driving and what it looks like after turning the truck off and back on. No major issues though other than the gauge reads high. Thoughts??? Alternator or bad battery?
ID:	102597   Click image for larger version
Old September 9th, 2014, 11:00 AM
high voltage is your alternator regulator. no buts about it. only way to confirm it's not the gauge is with a multimeter with your engine running.
not sure what engine you have, but my alternator has a replaceable regulator. cost $20
Mark Kellgren
KM4BOR
Old September 9th, 2014, 11:04 AM
atpick's Avatar
atpick
Andy
1990 110
Originally Posted by Overlander View Post
high voltage is your alternator regulator. no buts about it. only way to confirm it's not the gauge is with a multimeter with your engine running. not sure what engine you have, but my alternator has a replaceable regulator. cost $20
Ok cool that's what I was think it might be. It's a 200 TDI
------ Follow up post added September 9th, 2014 09:04 AM ------
Is it something that I need to be extremely worried about or can I slow roll it a few days?
Old September 9th, 2014, 11:06 AM
See if you can grab a pic of the alternator. The normal 65A model has a regulator that is easily replaceable. the 45 A model does not.
As stated, first measure voltage with a real gauge.
Old September 9th, 2014, 11:19 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
Please be careful with this "over charging" situation...your battery will start to boil and or explode depending on type...I speak from personal experience on this.
Old September 9th, 2014, 11:38 AM
josh-man's Avatar
josh-man
joshua
82 Land Rover 110 Ex MOD
This.
Old September 9th, 2014, 11:39 AM
Honestly that gauge is pretty useless. You really have no idea what the charge voltage is just by looking at it.
Old September 9th, 2014, 11:50 AM
Bill Larson
Bill Larson
True...just another tool in the tool box, very simple gauge. But it's an indicator...
Old September 9th, 2014, 11:56 AM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
As Bill hints, you need a voltmeter to see exactly what is happening, you just can't tell by looking at the stock gauge.
RDavisinVA
Old September 9th, 2014, 12:36 PM
atpick's Avatar
atpick
Andy
1990 110
Ok, sounds good, our household goods haven't arrived yet so I'll bum one off a friend or stop by Mansfield 4 x 4 and have them take a look
Old September 9th, 2014, 12:49 PM
atpick's Avatar
atpick
Andy
1990 110
Originally Posted by Red90 View Post
See if you can grab a pic of the alternator. The normal 65A model has a regulator that is easily replaceable. the 45 A model does not. As stated, first measure voltage with a real gauge.
Here are the best pics I could get with my wonderful iPhone
ID:	102601   Click image for larger version
Old September 9th, 2014, 12:56 PM
I think it is a 65A.
See the bolt on black/silver thing on the back of this picture. That is the regulator/brush assembly. If you have one of those, they cost around $20 and you can change it in 10 minutes.
Old September 9th, 2014, 01:00 PM
atpick's Avatar
atpick
Andy
1990 110
I think it is a 65A. See the bolt on black/silver thing on the back of this picture. That is the regulator/brush assembly. If you have one of those, they cost around $20 and you can change it in 10 minutes.
Awesome, thanks so much!
Old March 5th, 2015, 08:17 AM
broadstone's Avatar
broadstone
'84 CSW 90 '74 NADA III '97 CSW 110
Figured I would recycle this topic since I was looking for reasons why my volt gauge is pegged off the charts to the right. 1984 90 with it's original 2.3petrol (slightly glorified 2.25) I of course wanted to be sure there was not an overcharging issue back to the battery first. Brand new battery yesterday and reads perfect when not running, and when running I never exceeded 13.99 volts which proves I am not over charging. This is the first time I have started it since buying it over a year ago.
So I don't think it's my voltage regulator that's bad? Am I correct in thinking if it was a grounding issue it would read all the way left on the gauge, as in no reading? Testing with volt meter on the gauge posts reads around 12.6 when key switched on but not running which makes me think it's the gauge itself that is bad. Any thoughts?
Old March 5th, 2015, 09:06 AM
Bad ground on gauge.
13.9 is a tad low. 14.4 is the ideal number.
Old March 5th, 2015, 09:18 AM
broadstone's Avatar
broadstone
That was my initial thought but I have run a jumper from the ground post at the back of the gauge direct to the neg. on the battery, still pegged to the right.
Old March 5th, 2015, 09:28 AM
Bad INTERNAL ground on gauge
Old March 5th, 2015, 09:37 AM
broadstone's Avatar
broadstone
Gotcha, so basicly replace. I have no time, patience or attention span for electrical issues or as you have put it electrickery! Thanks, will order a new one.
alternator circuit voltage drop and ripple voltage values JFD Defender Technical Discussions 2 November 29th, 2010 08:13 AM
Strange voltage on accessory ignition/stereo switch Neo Defender Technical Discussions 1 November 1st, 2006 09:39 PM
3.9 MAF voltage boxerhips Defender Technical Discussions 6 January 15th, 2006 02:08 AM
air meter voltage adjustment? Rod Hayward Defender Technical Discussions 4 July 24th, 2005 11:24 PM
help - where is my voltage KeithD Defender Technical Discussions 26 November 13th, 2003 04:11 PM
