high revs - Defender Source
Old December 11th, 2003, 02:23 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
high revs
It has been getting a bit colder here, but hardly ever below freezing in the mornings when I start my truck.
I was wondering if anyone else had experienced anything of this nature:
When I fire it up, the RPM’s jump to about 2000 and hold there for a few seconds before dropping down in levels and eventually ending up at an idle of about 700.
From there, when I push in the clutch, sometimes the engine rev’s again up to about 1200 and I have to be gentle to get in 1st or reverse.
After it warms up, it seems to be OK, but still tough to get into 1st gear unless I am barely rolling or stopped.
It just seems to me that the RPMs should always drop when the clutch is engaged, or disengaged (not sure which) but sometimes they increase as I push in the clutch.
Is this “clutch slipping”?
Thanks,MM
Old December 11th, 2003, 06:55 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
I have the same problem, but mine started in the summer, and the dealer couldnt find anything wrong(no surprise) Anyways any info would be great
Kris
Old December 11th, 2003, 06:58 PM
milli's Avatar
milli
Michael D. Milliken
9590SW
It's also known as hessian start up.
Old December 11th, 2003, 07:01 PM
take it easy on the old girl haha. mine does that also but jumps to about 1500 when i start then settles to around 700 or so when it gets warm
Old December 12th, 2003, 02:24 AM
scot's Avatar
scot
Scot Yount
95 Coniston Green D-90 SW
Me thinks the stepper motor is malfunctioning....they can be removed, cleaned and lubed, to improve performance.
Wherever I go...there I am.
Old December 12th, 2003, 09:08 AM
jorge's Avatar
jorge
JORGE ESPINOZA
97 ST WHITE MODS SUPERCHARGED
My mechanic solved the same problem you descibe by removing the stepper motor and using carb cleaner. All has been normal since then.
Thule #420 high rise gutter mounts lactic For Sale - Parts 4 February 28th, 2006 11:25 AM
High altitude operation with a 3.8 EFI = CRAP? solihul Defender Technical Discussions 2 January 2nd, 2006 06:15 AM
Opinion on a high milage D90 Wagon jsilverman Defender Technical Discussions 4 November 10th, 2005 10:12 AM
Periodic High Pitch noise Joe P Defender Technical Discussions 3 July 18th, 2004 06:55 PM
