High Oil Pressure Causes? - Defender Source
Old July 15th, 2012, 10:48 AM
aosias's Avatar
aosias
Alexandra
1995 D90
300 Tdi with about 800 miles on it. Just did the break in oil change. Truck runs great overall. It's been sitting two weeks. Drove it yesterday and immediately after I started the oil pressure shot up over 80 psi (Gauge is set to alarm at one 80 psi). After the motor started to warm up the oil pressure dropped down to 30 psi at idle and 50-60 psi driving. Those have been the more normal numbers for her since the gauge was installed. She's been leaking oil from various different points over the last few weeks so this is the first time she isn't leaking oil.
What can cause this?
Alex
Old July 15th, 2012, 11:25 AM
carlosz's Avatar
carlosz
Carlos
totally normal fail safe mode of sending inmediate lube to critical parts of a cold engine, oil is cold, filter is full and sytem is primed, as soon as it starts, oil runs thru the galleries, as engine begins to warm up, viscosity begins to thin and thus your lower o/p, in winter you may see up to 100 psi for a short time. (maybe not the the best explanation but you get the point)
Old July 15th, 2012, 05:16 PM
the rover shop
shayne young
Man I wish I had the problem of TOO MUCH oil pressure in my old girl...LOL..
Mystik 15w50 and a flickering oil pressure light Naplm00 Defender Technical Discussions 3 May 1st, 2011 12:49 AM
low oil pressure at idle--sometimes cpk Defender Technical Discussions 5 February 7th, 2006 01:10 AM
1995 d90 no oil pressure bmwfastlyf Defender Technical Discussions 3 January 18th, 2006 03:10 AM
