High Idle - Defender Source
Old February 14th, 2006, 06:20 PM
tron's Avatar
tron
Thomas F
Recently Roverless
High Idle
I travel a lot for work and I left my D-90 in my covered car port for around a week. I got home and it would idle around 2K RPM for a few seconds, then drop down. After I would give it some gas it would do the same thing. It did not stall or idle low and it eventually went away by the second day I was home. Any ideas? Maybe just something needs to be cleaned?
Old February 14th, 2006, 08:36 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I'm chasing the same thing. Have an idea its either the stepper needing to be cleaned or a vac leak somewhere. Just haven't gotten around to fixing it
Jimmy Buffett
Old February 14th, 2006, 08:49 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
vac leak.
I looked for a vac leak & could not find one. i readjusted my idle & alls well.
if you adjust idle use 2 clamps on the hose & slowly release when done
Old February 15th, 2006, 01:10 AM
I had a problem with that one time and it was nothing more than the plastic barrel adjuster on the accelerator cable slipping in and out of its mounting point (at the bracket on the motor). After minor fiddling all was OK.
Old February 15th, 2006, 11:46 AM
tron's Avatar
tron
Thomas F
Recently Roverless
you have a picture of the accelerator cable? or can tell me where it is? i will take a look at adjusting the idle as well.
Old February 15th, 2006, 03:33 PM
My V8 accelerator cable is long gone, but you can follow it from the corner of the footwell up to the left side of the motor behind the plenum if I remember correctly.
idle
high idle only when moving question.. wantone Defender Technical Discussions 14 November 20th, 2009 07:03 PM
High idle problem MAF ? TPS? other? MonLand Defender Technical Discussions 30 February 5th, 2007 03:33 PM
High Idle on 97 D90 ndhlp Defender Technical Discussions 3 November 26th, 2006 11:59 AM
High Idle after Highway Cruise + stalling cellulararrest Defender Technical Discussions 3 October 11th, 2006 05:05 PM
Very high idle, sorta, just appeared yesterday Hans Defender Technical Discussions 3 December 6th, 2004 08:16 PM
