High Idle 2 ... (& random A/C question) - Defender Source
Old July 4th, 2011, 06:03 AM
norros's Avatar
norros
Nicholas Orros
1995 NAS D90 SW
Got a question for you 3.9 v8 lovers...
Every time I start my engine I'm getting a high idle, around 2,000, sometimes slightly higher. I don't run the A/C (next question) and I have new spark plugs, and run Amsoil everywhere. When the truck is warmed up, the idle is perfect. The IACV is clean... The local mechanic (a Jag/BMW/sometimes LR private shop... they suck) can't fix it. It took them 3 times to set the timing.
Any ideas? The initial idle stays high for sometimes a minute, it's getting out of hand.
My 2nd question has to do with A/C. I purchased a brand new A/C unit sometime in 2003/4... never freakin' use it. My wife and I do a lot of kayaking and I need it to work. There's a plug that goes into the engine to measure the temp to allow the A/C compressor to turn on. I have the original parts manual for this, that I actually took each page and put it in plastic... Well, my dumb ass took it out of the binder and now I don't know what that part is called OR the part #. It's a round plug, with 2 metal conductor pieces sticking out.
Anyway, Thanks.
Old July 4th, 2011, 12:55 PM
TS888's Avatar
TS888
Tony Sims
1984 110
I'm rusty on LR A/C, but just in general terms, for A/C stuff under the hood, there would be a power feed to the compressor, only one wire, and power/ground to the fans. The on/off cycle of the compressor should be signaled by a pressure switch. these are usually close to the expansion valve, which would be near the evaporator under the dash. Still, the pressure switch could be under the hood in a 90, since there isn't much room under the dash.
Tony
1984 110 "Smokey" (sold)
idle
high idle only when moving question.. wantone Defender Technical Discussions 14 November 20th, 2009 07:03 PM
High Idle tron Defender Technical Discussions 5 February 15th, 2006 03:33 PM
Very high idle, sorta, just appeared yesterday Hans Defender Technical Discussions 3 December 6th, 2004 08:16 PM
A/C Part Question. 48vphantom Defender Technical Discussions 2 August 27th, 2004 10:05 AM
A/c question Campbell Defender Technical Discussions 3 April 21st, 2004 04:41 PM
