High Beams cause Radio to short out... - Defender Source
Old April 21st, 2010, 02:32 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Hello All,
just got the Defender (from Aaron in NC) and all seems well so far. The only issue I can find is that the high beams cause the radio to short out... any ideas? I'm thinking i'll just rewire the radio from scratch this weekend regardless and check all grounds/cables/battery. Any other tips?
other than that -
LOVE
THIS
THING
Old April 21st, 2010, 06:47 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Is the radio stock? If it's an aftermarket unit, I'd check at the column. I bet someone used the high beam wire for power to the radio. It will be a blue wire with a white tracer(stripe). Look there. Also, check your grounds.... post what you find.
What tree?
Old April 21st, 2010, 11:32 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
not stock, wiring was there i just spliced into it. good call... i'm going to rewire this weekend and let you know what i find.
Old April 22nd, 2010, 07:54 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
what do you mean by short out? Fuse blows for the radio?
Legend in My Own Mind.
Old April 22nd, 2010, 01:37 PM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
cuts power.... 5 seconds..... comes back, no blown fuses (yet)
radio
Which Radio plugs work in 95 D90? Gkase Defender Technical Discussions 11 July 25th, 2011 12:41 PM
How do I get my radio to work???? Chris Cox Defender Technical Discussions 5 May 31st, 2008 09:49 PM
'97 Defender radio & changer setup? Defender50th Defender Technical Discussions 6 September 27th, 2005 11:22 PM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
