high beam troubles - Defender Source
Old May 17th, 2007, 10:37 PM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
high beam troubles
When I turn on the high beams, power is cut to all the front lights. This only happens if I switch them on (push the lever forward towards the dash) not if I hold them on (pull the lever towards myself). I already replaced the switch, but that didn`t do the trick. Any ideas?
Old May 18th, 2007, 12:38 PM
oldscratchggf
nate
95 d90
bump
Old May 19th, 2007, 04:53 PM
redrockrover's Avatar
redrockrover
Russell Phillips
1994 Defender 90
Just a quick guess I have would be the high beam switch. I would think the blinker/high beam lever in the forward position is not making a good connection. The terminals are burnt out. When you pull it back the terminals are making a good connection hence the high beams work. I had to replace my blinker/high beam lever and it is not a very hard job. It just takes a little bit of time. Hope this helps.
Russ
'94 AA Yellow
# 891
Old May 19th, 2007, 07:41 PM
ini88's Avatar
ini88
Daniel Marcello
Alloy+Grit Creative Director
check the connection in the high beam switch. my low beam switch connection burned out one time. I guess it gets real hot in there and can melt the plastic part that the connection is holding. i would say take it apart and see if the connection is burned out or loose.
Old May 19th, 2007, 07:45 PM
oldscratchggf
nate
95 d90
Already relpaced the switch, but no luck. any other ideas?
Thule #420 high rise gutter mounts lactic For Sale - Parts 4 February 28th, 2006 11:25 AM
High altitude operation with a 3.8 EFI = CRAP? solihul Defender Technical Discussions 2 January 2nd, 2006 06:15 AM
defender soft top, high miles, trade wrangler ? cafemosaic Wanted 0 December 4th, 2005 08:50 PM
Opinion on a high milage D90 Wagon jsilverman Defender Technical Discussions 4 November 10th, 2005 10:12 AM
» Defender Registry
Rubicon
Sharmin
Bella
D110DC
Add your Defender
