High Beam Help - Defender Source
Old January 31st, 2011, 09:21 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
High Beam Help
Finally got everything wired back up and everything works except the high beams. Headlights come on as they should but when I hit the high beam switch they go off completely. Any ideas/advice?
Old February 1st, 2011, 08:35 AM
LRover's Avatar
LRover
J. Michael McCaig
When I had that problem it was the switch.
Old February 1st, 2011, 09:28 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Thanks Michael...
Old February 2nd, 2011, 01:29 AM
CDNRover's Avatar
CDNRover
Jeff Labbé
110 Ex-Mod FFR 200tdi
Same problem but instead of the switch it was the way I wired the headlamp; I had electric feedback to the high beam warning light.
Old February 2nd, 2011, 10:42 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Jeff, can you elaborate? Not sure I follow what your are saying. I suspect it's a wiring issue though becuase everything worked when I took it apart.
Old February 2nd, 2011, 11:31 PM
CDNRover's Avatar
CDNRover
Jeff Labbé
Have you done the wiring to the bulb? I had to do the wiring that connects to the bulb (headlamp) and I mistakenly interchange the positions. It's a 3 pin connector but if you interchange them.... That was my mistake. When I flick the high beams on the energy was going back to the high beam warning light (blue witness in the dash) and made it glow real bright. The headlamps were working alright into the "ON" position but as soon as I try using the high beam..... nothing.... If it can help you out, I confess my mistake.. Laugh at me if you want now! =) You might know the old French saying : "Sometimes being too close to tree makes you forget you're in a forest".
JEff
Old February 7th, 2011, 08:03 PM
RiftRover's Avatar
RiftRover
Mike Barnett
110
Does anyone know if there is a relay associated with the high beams? The wiring diagram doesn't really show them but I can hear one click with the low beams. The relays are not labeled.
Old February 7th, 2011, 08:26 PM
no relays associated with the headlights at least on a 95 - i assume the 89 is the same way.
95' D90 - daily driver..
WTB Headlight and high beam switches for 94 D90 easy Wanted 2 October 15th, 2010 04:40 PM
high beam troubles oldscratchggf Defender Technical Discussions 4 May 19th, 2007 07:45 PM
Thule #420 high rise gutter mounts lactic For Sale - Parts 4 February 28th, 2006 11:25 AM
Opinion on a high milage D90 Wagon jsilverman Defender Technical Discussions 4 November 10th, 2005 10:12 AM
