HID's - Page 2 - Defender Source
Old May 19th, 2010, 12:27 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Originally Posted by Red90 View Post
Osram/Sylvania do still make "proper" 7" Bi-xenon HID housings... There are two main models.
Xe7R, http://suvlights.com/product_info.php?products_id=267
XP6024, http://suvlights.com/product_info.php?products_id=255
Interesting, I had tried to find them on Sylvania's site without success. The original examples I had seen looked alot more 'normal' than your second link, and actually used a halogne bulb for the high beam, instead of a Bi-Xeon light source, so in that regard it looks like the first link you posted may be an updated version.
Certainly a better way to go than fitting an 'HID Conversion' bulb to a Halogen headlamp system.
------ Follow up post added May 19th, 2010 12:28 PM ------
Found a link to an article dating back to 2002 regarding the original Sylvania 7" round HID replacements I had seen, just for kicks..
~Scott T.
'95 D-90 ST - AA Yellow
Old May 19th, 2010, 02:09 PM
Yes, if you look around on that site, they also do a version with HID low, halogen high. I did not mention it as that is retarded....
The first ones are the reflector style and the second the projector style. Lighting is supposed to be better with the projectors, but they look stupid, IMO...
edit: and yes, they are not on any of the manufacturers' sites...
Headlight HID Conversion CDN38 Defender Technical Discussions 75 May 1st, 2013 01:48 PM
Hella wiring retard Andrew Vick Defender Technical Discussions 5 March 18th, 2007 01:09 PM
Hella Driving Light Add - Best? Kimos Defender Technical Discussions 43 October 26th, 2006 01:16 AM
Light's Joe P Misc. Chit-Chat 8 March 2nd, 2004 10:28 AM
