hiding the overhead ralleye lamp wires - Defender Source
Old March 28th, 2004, 09:41 AM
GeoParth's Avatar
GeoParth
George Parthmer
1995/d-90 #2715 yellowST
I am going to install one set of used hella 1000's and one set of new hella black magic 1000 lamps above the windscreen as ralleye lights this coming weekend. I am simply waiting for rovers north to get the wiring harness to me for the used set and hopefully I will be ready to go. As I took an initial survey of the mounting tabs on the Rover I didn't see any corresponding holes through which to run the wiring. Therefore, I am posting here to find out where the best place to 1) hide the wires and 2) bring the wiring into the cab might be. Thank you in advance for any assistance that you may be able to provide.
Old March 29th, 2004, 04:03 PM
pangaea's Avatar
pangaea
Nathan Hindman
95 Discovery, D130
Why not just run the wiring down the inside of the roll cage? Put some black shrink tubing on the wires and then zip tie them to the cage and it'll look pretty clean...
As far as running it into the cab, I'd suggest going down the inside of the bulkhead, along the chassis and then into the seatbox. mount the relay in there and it'll be pretty well protected from the elements.
Nathan Hindman
http://www.pangaea-expeditions.com
lamp
License Plate LED Lamp & Rear Fog Lamp Install LenB Smaller Projects 24 December 16th, 2007 08:54 PM
Orange Check Engine Lamp Scoop Defender Technical Discussions 9 March 12th, 2006 07:51 AM
Spark Plug/ ignition wires mdmccallum Defender Technical Discussions 3 September 1st, 2005 11:48 AM
Piaa 90 Xt Pro Dual Lamp System bruinlad For Sale - Parts 2 March 21st, 2005 08:36 PM
Rear (Red) fog lamp? dmarchand Misc. Chit-Chat 24 August 4th, 2004 10:53 AM
