Hi-Lo-CDL shifter, Auto vs Manual? - Defender Source
Old March 12th, 2008, 10:59 PM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Is it true the Xfr case shifter assembly and mount are different on an Auto vs a Manual D90?
Gary
Old March 17th, 2008, 12:36 AM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
This is not exactly your case, but it may help. I put a disco xfer case (auto) in our 95 d-90 (manual) and everything bolted right up and fit perfectly. The one thing that is different between the two cases is the shift-lock solenoid. It is only on the auto transmissions and it simply prevents you from shifting the t-case unless the trans is in neutral. t-cases from manual trucks don't have this.
Old March 17th, 2008, 12:42 AM
PCRover's Avatar
PCRover
Gary Young
'94 90ST -> SW
Thanks for the reply, I think that may be the only difference. At least that is the only difference brought up so far...
Gary
cd, manual
WTT Auto for Manual mpsteil Wanted 8 June 16th, 2009 09:31 AM
More on diesel / manual conversions Delta95 Defender Technical Discussions 37 September 4th, 2008 11:31 AM
Need 97 auto trans shifter light unit thingy wicks Wanted 2 December 22nd, 2004 12:59 PM
Manual To Auto Conversion willtillery Defender Technical Discussions 2 September 22nd, 2004 10:12 PM
How difficult is it to convert auto trans to manual in a D90? jaherring Defender Technical Discussions 14 June 17th, 2004 02:05 PM
