Hi-Lift or Jackall? - Defender Source
Old January 28th, 2004, 03:53 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Hi-Lift or Jackall?
Hi-Lift or Jackall?
Is there really a difference besides where they're made?
Old January 28th, 2004, 11:33 AM
tbmcneill
Guest
Posts: n/a
Hi-lift. in a crunch you can remove the handle & use it as a drag link ...an almost perfect fit. Jackall's handle is welded to the lifter & can't be removed.
T
Old January 28th, 2004, 11:40 AM
High lift handle is also very useful to get extra leverage when getting bolts off with a breaker-bar. And in the right hands it can look very threatening.
Old January 29th, 2004, 07:10 PM
pangaea's Avatar
pangaea
Nathan Hindman
95 Discovery, D130
Agreed. The Hi-lift handle has been my savior with a few stubborn bolts. As a matter of fact, I think I've used my Hi-lift more as a breaker bar than as a jack.
Nathan
Nathan Hindman
http://www.pangaea-expeditions.com
ac
4-5" lift springs for rear of RRC Shane@EVS Wanted 0 March 16th, 2006 03:09 AM
Actual lift measurement with OME KevinNY Defender Technical Discussions 1 February 2nd, 2006 04:18 PM
Tires sizes per lift ratio ini88 Defender Technical Discussions 9 December 22nd, 2005 01:02 AM
Rovers North 1.5 inch lift kit w/shocks Seriesman For Sale - Parts 1 August 26th, 2005 11:45 PM
Inexpensive, minor lift ideas sought.. LRNAD90 Defender Technical Discussions 1 September 16th, 2004 06:59 PM
