Hi-Lift Jack wont jack down - WTF? - Defender Source
Old March 31st, 2016, 01:49 AM
agentmulder
Agent Mulder
2008 110 PUMA
As per title - I googled it, lot's of forums suggesting that it needed lube on the pins, however, fun fact:
  • It's brand new - still had factory lube on it.
WD40 applied anyway - still wont go down, it'll just rock up and then down the same distance for each stroke, no pin action.
It's an interesting mechanism, but a wee bit hard to be sure of what it's meant to do as the issue mean I've never actually seen what it's meant to do
Lucky I had access to a standard LR jack or I'd be kicking the Defender over to get the jack out.
So, anyways, in a moment of zen-like reflection I notice that a pin- er.. -pin (?) (the pin that goes through the pin) is bent.
Is this normal?
I suspect not...
Old March 31st, 2016, 02:00 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Ah the joy of the extremely useful and yet finicky and often dangerous hi-lift...yeah, that pin is meant to be straight. Strange that it was bent right off the bat, I've had to rebuild mine a few times but always after some abuse.
Old March 31st, 2016, 02:34 AM
agentmulder
Agent Mulder
2008 110 PUMA
Yeah, I figured - thanks for the confirmation.
Annoying , but ah well...
I'm certainly not going to bend it back myself and expect happy times - I don't know what I don't know about what would happen if it broke, but in the same breath and given time I might convince myself that a home made replacement would be fine - hopefully First Four will come through with a replacement free of charge though.
The cross-pin (that's what I call it now) is in the HiLift pin maintenance kit.
Old March 31st, 2016, 03:18 AM
Ray_G's Avatar
Ray_G
Ray Gerber
Def don't bend it back, use that maint kit; I usually order these two at a time (one for immediate replacement parts, one for the next time it breaks on the trail).
Amazon.com: Hi-Lift Jack FK-1 Fix-It-Kit: Automotive
Old April 1st, 2016, 02:40 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Happens all the time to me. you need to use your fingers to pull the lower pin out and it will drop. it gets bound up. just get the handle so the weight is in the top pin, then manually pull out the lower pin, drop the handle town, engage the lower pin, etc. and it will go down.
Old April 1st, 2016, 02:57 PM
Every time I look at a Hi-Lift jack I wonder how many people get injured of killed each year by one.
Old April 1st, 2016, 03:10 PM
fruitpunch
Marc Brouwer
66 IIa 88 Perkins powered
WD40 it more
Old April 1st, 2016, 03:16 PM
About 2:05 into the video
http://youtube/mDVau7w-WIk
Old April 1st, 2016, 03:32 PM
I had my brand new Hi Lift do that at Winter Romp, but I attributed it to the extreme cold cause the grease to become too thick.
Old April 2nd, 2016, 07:00 PM
John_Karlsson
John Karlsson
1966 Series IIA 88 SW
I bought one fo my Hi-Lifts back in the '60s. It still works perfectly, but sometimes it needs a spritz of oil.
John Karlsson
Hope Valley, RI
ac
crooked roll down / wind down windows sonoronos Defender Technical Discussions 2 May 23rd, 2011 11:29 PM
Jack All Expedition Jack WLDKGDM For Sale - Parts 15 March 4th, 2011 11:29 AM
Takala Air Jack - Like X-jack Zimbo76 For Sale - Parts 0 November 21st, 2008 06:29 PM
Hi-Lift slide-n-lock tie down system aosias Defender Technical Discussions 8 October 31st, 2008 11:34 AM
Mounting hi lift jack to Brush guard Cyborg Defender Technical Discussions 12 May 3rd, 2004 10:09 AM
» Defender Registry
90 V8
KeithD
Bertha
jackstraw
Add your Defender
