Hi-Lift Jack Spare Wheel Mount - Defender Source
Old January 15th, 2011, 10:15 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Anyone have experience with this??
Anyone have a good source to get this??
http://www.kaymarcarrier.ru/products...ckholderkaymar
Old January 16th, 2011, 12:18 PM
I have one by Safari Guard that I like, but I don't think you can get them anymore. Should be pretty easy to make though. They look like this
http://forums.lr4x4.com/index.php?showtopic=1645
Originally Posted by pendy
I'm here for the D's
Old January 16th, 2011, 03:20 PM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
Thanks for the responses.
Understand the points made.
Not too afraid it will hit anything as it's pretty high up and the tire is a bit back.....so the departure angle should be minimally affected.
I've got a Rockware bumper and tire carrier. I would NOT do this if the tire was mounted to the door or the body. Probably best would be the front bumper or bull bar.
Does anyone have a lead on a body/bumper mounted system?
Old January 16th, 2011, 03:45 PM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I have been eying something like this but haven't pulled the trigger yet. Anyone else used this?
http://www.quadratec.com/products/92200_901X_PG.htm
Old January 16th, 2011, 06:37 PM
AmityD90's Avatar
AmityD90
Gery
1987 ROW D90
After searching for a SG one to no avail, I got that one made by hi lift.
No complaints so far. Pretty sturdy.
Good chance down the road I will be getting a rockware rear tire carrier with hi lift mount. So for now, when I'm not running with my roofrack it will do just fine.
Old January 16th, 2011, 11:27 PM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I have a SG one.
The SG one didn't affect departure at all. It sits up high enough depending on where you mount it.
It's ok but I would prefer a tire carrier/gas/hi lift combo.
Old January 17th, 2011, 12:59 AM
surf110's Avatar
surf110
Ze
130 Project
http://fourtreks.com/hi_lift_roll_bar_mounts_1_75_.html
Old January 17th, 2011, 03:03 AM
diesel_jim's Avatar
diesel_jim
Jamie Austin
I had a similar one on my old 90. was a right royal PITA....
if you reversed into anything (not that i did often though) you could bend the shaft of the jack; off roading through deep gullies would catch the bottom of the jack and bend it or break the mount.
But the worst thing... was all the road dirt that sprayed up onto the jack, so when you dod want to use it, it was covered in crap and the linkage would jam up.
spray it in oil or WD40? even more crap sticks to it then!
i now keep it inside my truck... much better! less chance of getting stolen too.
Old January 18th, 2011, 05:14 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
Until recently I had my hilift across the top of a 'shrockworks' rear tire carrier.
PITA is right! Cost two sets of liftgate struts from family slamming the carrier shut with the lift gate open. Had 3 stiches in my eyebrow from walking around the back of the truck with the gate open. Only then did I move the jack forward to the top of the Rockware bumper brush guard!
"I think you need a little weatherstripping - right here..."
Old January 18th, 2011, 05:27 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Yep mine's inside out of the reach of road muck and sticky fingered low life criminals too
Mike Hammond
Old January 18th, 2011, 06:07 PM
Rugbier's Avatar
Rugbier
Gustavo
I have 2 SG used in good conditiln.
Pm offet, if it makes sense I might sell them
NO SIGNATURE
Old January 19th, 2011, 09:19 AM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
x3 - maybe not as quick as an outside mount to get it out but then again I haven't had to use it much at all.
Get 4 bolts with wingnuts and use the base as a plate to sandwich the roll bar. I then made another plate for the other side.
http://d90.unionstreetbikes.com/medi...mpseats_up.jpg
Old January 21st, 2011, 07:57 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
I had one of mine mounted on the spare on one of my Disco's using a bracket I made (it's not difficult to make a locking bracket if you have a welder). I took it off when the top of my jack hit something and bent the bar.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old January 22nd, 2011, 01:52 AM
Cred's Avatar
Cred
Clarence
1994 D90 #1057
I found one you might like. Should fit your rear wheel just fine.
http://www.lrsoffroad.co.uk/node/119
ac, mount, spare, wheel
Steel versus Alloy Wheel Bonnet Mounted Spare Kit ronward Defender Technical Discussions 9 October 19th, 2005 01:18 PM
Spare Tire mount on hood Viper-25 Defender Technical Discussions 20 July 24th, 2005 10:36 AM
Rear spare tire mount - nuts Kimos Wanted 1 December 4th, 2004 08:17 PM
Hi lift mount Britt Easterly Misc. Chit-Chat 6 May 5th, 2004 06:19 AM
Mounting hi lift jack to Brush guard Cyborg Defender Technical Discussions 12 May 3rd, 2004 10:09 AM
