Hesitation under acceleration - Defender Source
Old June 18th, 2009, 10:55 AM
durangorover
Chris Wherry
1995 D-90
I'm getting a hesitation when I'm accelerating. I feel it more in 3rd and 4th but it seems to be totally random. It's like it accelerates fine but will skip one beat in there somewhere. The issue doesn't happen or I haven't felt it when decelerating. The rpms don't change(drop) either. I can hear the change in the exhaust a little since I have the top off. I replaced the fuel filter and that didn't seem to do the trick. I've also just recently replaced the water pump, thermo, and belts. Don't know if that had anything to do with it. One of the belts is squeaky on start up though. It's like if you were walking along and someone grabbed the back of your shirt for a second. Any ideas?
Old June 18th, 2009, 11:15 AM
nikojo's Avatar
nikojo
D90 SW -- 2.8PS
do the RPM's go up slightly?? clutch slipping??
tends to go in the upper gears first.
Old June 18th, 2009, 11:26 AM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
Stupid as this sounds, check your driver's side motor mount. My RRC had a broken mount and I was getting odd vibrations from the drive train as well as wierd hiccups from the motor as a result of the motor torquing. Once it was fixed it is smooth again.
Worth a look.
Old June 18th, 2009, 12:39 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
Throttle Position Sensor would be my guess. There may be a dead spot in it somewhere. You could test it.
Old June 18th, 2009, 05:29 PM
durangorover
Chris Wherry
1995 D-90
Clutch isn't slipping and I'll look into the motor mount. I don't know about the throttle sensor. How can you check that?
Old June 18th, 2009, 05:33 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Could also be a cheap distributor cap or yours just needs replacing? How long since last plugs, wires, cap and rotor?
Old June 18th, 2009, 07:20 PM
durangorover
Chris Wherry
1995 D-90
Plugs, wires, cap and rotor are all new and I just realized that I replaced the throttle positioning sensor last summer. I tested to see if it would happen if the car was neutral and revd the engine and it did not happen. I did have the exhaust replaced last year (from behind the cats) but didn't change the O2 sensors. Could this make a difference?
Old June 18th, 2009, 10:44 PM
durangorover
Chris Wherry
1995 D-90
Sorry I was wrong. I didn't replace the TPS. I replaced the stepper motor. I see if I can get the TPS checked.
Old June 19th, 2009, 02:17 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Silly as it sounds, check the vacuum line coming out of the distributor.
Then check your timing as well. Make sure it's advancing when you rev the engine too.
-Hans
My oil line fix
My 100k stopped odometer fix
Old June 24th, 2009, 10:29 AM
durangorover
Chris Wherry
1995 D-90
Was out of town for a week so I just got to playing a little more with this issue. Got the TPS tested and it seems to be working just fine. I had some new o2 sensors that I haven't put on yet so I threw those on as well. Went for a test drive and my issue seems to be getting worse. Now its really bad around 2-3k rpm as well as it sounds like the exhaust is very restricted(banana in the tail pipe?). Almost backfired a couple times. Any thoughts? Thanks
Old June 24th, 2009, 11:00 AM
landrovered
S. Smith
Bad plug wires? Sounds like it is misfiring any codes?
Old June 24th, 2009, 12:29 PM
durangorover
Chris Wherry
1995 D-90
I have new wires, plugs, rotor, cap. As far as I know, no codes. To tell the truth, I've never seen my ECU light up at all. Never seen a code. I adjusted the base idle last fall because of a stalling issue at idle. The one thing I didn't do was check the timing. Could that be it?
Old June 24th, 2009, 12:38 PM
landrovered
S. Smith
Trying to backfire says timing to me.
Old June 24th, 2009, 02:03 PM
cellulararrest
Chris Snyder
Did you ever fix the actual issue causing the stalling? Shouldn't have had to touch the base idle. That might be contributing to this problem.
I would check your timing as well. Maybe the distributor is loose.
Old June 24th, 2009, 02:15 PM
durangorover
Chris Wherry
1995 D-90
Adjusting the base idle did help the stalling when coming to a stop issue for the most part. It's stalled once or twice since. I haven't adjusted the timing. I don't have a timing light nor do I know how to operate one. I'll check to see if the distributor is loose.
Old June 24th, 2009, 02:29 PM
cellulararrest
Chris Snyder
Well yeah, it would but only by increasing the idle speed. You just covered up another issue.
Old June 24th, 2009, 07:17 PM
Chris Vitale's Avatar
Chris Vitale
'95 D90 ST 2.8L TDi #2050
I had the same problem. After lots of research, I replaced the alternator and the problem was fixed. The cause of the problem was a bad diode. Good luck.
ac
Intermittent Acceleration Failure ONLY from Stop -- 97 D90 pcscharfe Defender Technical Discussions 24 September 23rd, 2011 09:58 AM
Hesitation 88 RRC, Bad TPS? scoot_mcgrute Defender Technical Discussions 2 July 30th, 2009 11:47 PM
Stumbling during acceleration and load Bozman Defender Technical Discussions 8 June 14th, 2006 08:02 AM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
Hesitation kiefffff Defender Technical Discussions 6 August 23rd, 2004 10:54 PM
