Hesitation/stalling on throttle let-off (200tdi) - Defender Source
Old February 21st, 2012, 10:39 AM
Well, thanks everyone for the help on the fuel tank. After a week of de-rusting in phosphoric acid, rattling with bits of chain, separating the skid from the tank itself (thanks DB), powerwashing and power-sanding off all the factory adhesive and rust between the skid and the fuel tank (thanks Jeff), discovering pinholes all over the bottom, filling the entire bottom of the tank with a generous coating of epoxy, drilling drain holes in the skid, cold-galving and repainting everything, and riveting the skid to the tank...well...it's done and the truck runs great.
The latest issue though is hesitation when I let off the throttle.
Idle was around 900rpm when I first start the truck. No problems. When I traveled at highway speeds and come to a stop, the engine's idle dropped to 500-700, and sounded like it was about to stall out. Often it did stall out. I had to press the accelerator gently to keep the revs up.
I gently adjusted the idle screw out on the injection pump and now the idle is around 950rpm. That seemed to solve the stall-out problem.
Was that the right fix for the problem? Or am I tempting fate by adjusting the idle screw, and should I have adjusted something else instead? Is this a sign that I should run cleaner through my system, clean or replace the injectors?
Old February 21st, 2012, 03:32 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
Run injector cleaner through the system as a first step.
Make sure there's no air leak on the fuel lines.
Check the vent on the fuel cap isn't blocked.
Make sure the lift pump is good.
Check the easy / cheap things first.
With the muck in the fuel tank problem it might be worth getting the injectors checked as the next / more expensive step.
Mike Hammond
Old February 21st, 2012, 04:03 PM
Thanks for the response, Mike - and your continued help!
I'll run a few liters of Lubrimoly Diesel Purge through the engine and check on the fuel lines for leaks. Fuel cap vent works for sure as I tested it last week.
I've noticed that I've been getting a little diesel in the oil...LR forums seem to point to a leak in the lift pump diaphragm...does that sound like a possibility?
Old February 21st, 2012, 04:05 PM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
Is it possible there a bunch of junk in the filter now and check the throttle cable and return stop on the IP.
Old February 21st, 2012, 04:08 PM
mikeslandrover
Mike Hammond
I put the lift pump from my 110 on prior to shipping it out to you. If there's diesel in the sump it can only get there via the lift pump leaking. Change that out first.
Mike Hammond
Old February 21st, 2012, 04:10 PM
good stuff....i'll get one on order, thanks Mike.
Old February 21st, 2012, 04:12 PM
mikeslandrover
Mike Hammond
I meant to say check/change out the main fuel filter too.
A blocked main fuel filter will limit top end power much more than tick over speed.
Mike Hammond
Old February 21st, 2012, 04:16 PM
Ed:
Where are you ordering the lift pump from? I've been toying with changing mine out as well.
Old February 21st, 2012, 04:48 PM
Hey Jason, I am thinking either Rovers Down South (STC1190 - $75) for the genuine article or British Pacific (ETC7869 - $23.50) for the allmakes version. I don't think the Allmakes is too bad honestly.
I think the 300tdi has a slightly different pump from the 2.5TD / 200TDI but I could be mistaken.
I need new shift knobs for the LT77/LT230 so I'll probably end up getting those too.
Old February 21st, 2012, 05:00 PM
I'd go RDS...George is a good egg. I'll probably order mine up later this week from him.
200tdi, tdi
1993 LR90 200tdi. globallandrovers The Vendors Loft 1 October 11th, 2006 07:16 AM
Pinging under full throttle... Doug Defender Technical Discussions 10 November 29th, 2005 11:02 AM
difference: Disco 200tdi and Defender 200tdi? jaherring Defender Technical Discussions 30 June 3rd, 2005 10:10 AM
Throttle body size on a Thor manifold? Hans Defender Technical Discussions 1 March 10th, 2005 10:10 PM
Hand Throttle sherpamike Defender Technical Discussions 19 April 3rd, 2004 12:23 AM
