Hesitation 88 RRC, Bad TPS? - Defender Source
Old July 30th, 2009, 06:58 PM
scoot_mcgrute
Scott S
1988 RRC Truck Cab
Picked up the rig a few weeks ago and it's had a hesitation under full throttle starting around 2500 rpms or so. The vacuum advance was not hooked up correctly (delay valve was backwards) and it needed a stepper motor so I fixed those things. Since then, the idle has been ok most of the time, but has dropped occasionally to around 150-200 rpms with a rough idle. I changed the vacuum advance today and it helped for a little bit but was back to it's old habits again.
I pulled the TPS of and hooked it up to my multimeter and recorded the results. Now, I'm guessing by the jump that I need a new TPS, but what do you guys think?
http://smg.photobucket.com/albums/v7...t=MOV03199.flv
Old July 30th, 2009, 11:24 PM
crown14's Avatar
crown14
Verticalscrote
Volkswagen Super Beetle
well two problems
1. tough to make sense of the video without seeing the throttle move also
2. i think your meter settings are wrong or your connections were bad (or the meter battery is bad? seen that make them act funny before too) but theres no way you are getting more than battery voltage at the tps.
Old July 30th, 2009, 11:47 PM
scoot_mcgrute
Scott S
1988 RRC Truck Cab
That's resistance, not voltage. It's moving from no throttle to full throttle starting at 00.3 ohms and spiking up near 110 ohms before settling back down to around 13 ohms or so. Shouldn't it stay at a constant increasing rate all the way instead of spiking like that?
On another note went for a drive with a stop in between and it ran with hesitation before the stop and ran like a top after. I'll see what it's doing tomorrow again.
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
02 Disco & 95 RRC Stuff newfD90 For Sale - Parts 0 July 17th, 2005 11:17 AM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
DII LT-230 in Old RRC, HELP Please. RedRhinoProducts Defender Technical Discussions 1 November 6th, 2004 02:24 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
