Hesitation - Defender Source
Old August 23rd, 2004, 11:38 AM
kiefffff's Avatar
kiefffff
Keith Rider
1994 Portofino ST: #217
Hesitation
While driving home last night the truck started to hesitate and felt very sluggish when trying to accelerate. The truck was fine, then all of a sudden it started after I slowed for a light and left turn. Really weird. Anyone experience this before or have insight into the possible problem? Thanks.
Ohh yeah, I lost my start up jingles a few months ago too. That is probably a fuse.
Old August 23rd, 2004, 11:47 AM
LOL start up jingles, I haven't heard those in over a year. Has the ECU thrown any codes? did you just fill up on gas at all? Change the fuel filter in the last couple years? We need more details man!
Old August 23rd, 2004, 12:02 PM
kiefffff's Avatar
kiefffff
Keith Rider
Don't think the ECU has thrown any codes? No check engine light, etc, as of right now. Everything has been aokay up until about 9 blocks from my house. That's when this hesitation/engine sputtering thing started. The tank is 1/2 full right now. Filled up a few weeks ago. Might have condensation in gas. A lot of rain down here in Virginia this summer. (MAR will be super muddy!) Don't think the fuel filter, etc. has been changed in years. I have only had the truck for 1.5 years and I know I haven't touched the fuel filter, etc. Also hear buzzing noise from fuel pump in rear. That normal?
Old August 23rd, 2004, 12:08 PM
How loud is the pump, you should be able to hear it when you turn the key to on but once the engine starts I don't think you should be able to hear it (not because it switches off but because it is very quiet), I can barely hear mine with the engine off. A lot of the time when your fuel pump goes it starts screaming, but I would check the cheap things first like the fuel filter and put some dry gas (I think thatís what they call it) in the gas to get rid of any water in the tank (just make sure it works with fuel injectors). You may just want to drive it for a while and then try a fresh tank of gas.
Old August 23rd, 2004, 12:16 PM
kiefffff's Avatar
kiefffff
Keith Rider
Its a slight humming/buzzing sound. You can hear it over the exhaust though. I'll try filling it up with some new gas and dump some STP fuel injector cleaner in there and see if that works. I hope that's all it is!
Old August 23rd, 2004, 03:56 PM
Bowtracer's Avatar
Bowtracer
Peter Sherman
NAS 110
you may want to look at your ignition. cap & rotor [condensation], check wires esp at the coil,make sure they are on all the way.
Old August 23rd, 2004, 10:54 PM
kiefffff's Avatar
kiefffff
Keith Rider
Well, when I got home from work I took it for a "test" drive and it drove fine. Really weird. Maybe it was moisture. Plan to do the 60,000 mile maintenance soon. Hopefully that will solve any issue.
Hesitation 88 RRC, Bad TPS? scoot_mcgrute Defender Technical Discussions 2 July 30th, 2009 11:47 PM
Hesitation under acceleration durangorover Defender Technical Discussions 16 June 24th, 2009 07:17 PM
Condensation in gas tank Antonios Defender Technical Discussions 25 March 25th, 2006 09:38 PM
ZF Transmission Hesitation Shifting 1of40 Defender Technical Discussions 1 July 26th, 2005 11:41 AM
