Help wth Fuel Gauge (that works sometimes) - Defender Source
Old July 2nd, 2004, 09:54 AM
ToyCrusher
Douglas Woodworth
Question Help wth Fuel Gauge (that works sometimes)
Greetings Ė
Does anyone have experience with a D90 (97) Fuel Gauge? Iíve got a wild one. It bounces from true level to empty and anywhere in between at random (a problem even on the highway). Iíd like to fix it but I donít want to have to drop the tank to look over the sending unit if I donít have to.
Unfortunately Iím not familiar with the system. Could it just be a bad ground someplace Ė maybe somebody has had a similar problem.
Old October 18th, 2004, 02:14 PM
rustydefender
Russell Newton
97 D-90 sw
I second that mine is crazy too im lookin for the same answer
Old October 18th, 2004, 02:30 PM
They all do it, and this has been posted before.
Old October 18th, 2004, 03:13 PM
loykd's Avatar
loykd
Ken Loy
1994 Portofino Red ST
yeah, me too! another one of my recent electrical problems. I've been using my odometer as a gas gauge. The other day I filled up to 14.8 gal!
Old October 18th, 2004, 07:06 PM
WCURoverD90's Avatar
WCURoverD90
Jason Habbal
1997 Defender 90 #1104
They all do that...I usually fill up when it says its near a quarter tank...Don't want to be the guy with the D90 parked on the side of the road in Charlotte out of gas....Not that i drive it that much anyways....No worries though
"tell them to phucough"
Land Rover-The Best 4x4xFar
Old October 20th, 2004, 01:25 AM
loykd's Avatar
loykd
Ken Loy
Hey Molinator, Search doesn't show anything else on this problem. How 'bout whipping out some of your Ninja powers and help your bruddas out?
What causes the erratic fuel indications? Is it the gauge or the sensor?
Old October 20th, 2004, 09:23 AM
hmmmmm
http://www.defendersource.com/forum/...ead.php?t=2000
http://www.defendersource.com/forum/...ead.php?t=1148
I would also guess that the problem has to do with the sender in the tank and the way the tank is, mine is very affected by movement in any direction so when fuel gets sloshed around the sender does not read correctly.
Old October 20th, 2004, 11:50 AM
loykd's Avatar
loykd
Ken Loy
Thanks Mike. My latest problem is not the sloshing around of fuel in the tank causing erratic fuel level indications, but the fuel guage not indication correctly at any fuel level. I filled up and the highest the guage got was 1/3 full. It's been degrading slowly over the past month or so, and I'm wondering if I need to replace the gauge or the in-tank sensor.
How can I check if the gauge is getting a proper signal?
Old October 20th, 2004, 12:02 PM
Swap it wit one from someone elses 90, I think it is easy enough to do, we can sawp this weekend.
Old October 20th, 2004, 12:12 PM
the only problem I have with my fuel gage is the indicatorgoes from right to left too fast
Old October 20th, 2004, 02:19 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
this should be a fun weekend. we'll have ken's truck in pieces
Jimmy Buffett
Old October 20th, 2004, 02:36 PM
Well at lest he is bringing his truck, and if you bring yours then we'll have a source for spare parts.
Ken, have you checked that the connectors on the back of the gauge are clean?
Old October 20th, 2004, 02:50 PM
loykd's Avatar
loykd
Ken Loy
Mike, gimme a LITTLE credit... haha... yes, the connectors checked and the fusebox too Oh, and I checked the tire pressure too; it's ok so that probably isn't causing the problem.
Check resistance (or would it be voltage) at the indicator? Would that be a good check for gauge health?
Old October 20th, 2004, 03:45 PM
Good thought! I'll have too pull mine out and check what the voltage is when the tank is full and empty, then you can compare it to yours! If it reads lower then mine when full I would check for bad wiring before dropping the tank.
Old October 20th, 2004, 08:43 PM
flippedrover
Tyler
'94 D-90
Yeah yeah yeah. Not sure you'd want any parts from my truck.
Jimmy Buffett
fuel
fuel gauge ohm range naeirie Defender Technical Discussions 35 September 6th, 2017 02:49 PM
Fuel gauge - no reading JackW Defender Technical Discussions 2 October 11th, 2005 03:50 PM
» Defender Registry
Jon Snow
huibae
Maggie
rankar
Add your Defender
