help with wiper motor ghosts - Defender Source
Old December 19th, 2012, 08:25 PM
paluskat
Tom Paluska
D110 200TDI
My wiper switch turns the wipers on but they turn off when they feel like it - in any setting, momentary, regular, fast. Got a new switch lever but it doesn't seem to help the problem. Wipers go on as desired but take 1-5min to turn off. ??? so annoying. Sometimes it works as desired but rarely. Any suggestions? I though about putting a kill toggle switch at the base of the steering column but that really is just a band-aid. Motor works great in slow/fast settings.
Old December 19th, 2012, 08:31 PM
problem is with the wiper motor. There is a fastener @ the bottom that can cause this. Best plan is to just replace it.
Old December 19th, 2012, 09:04 PM
Howsomever
Wayne Phelps
1984 D110
If you are mechanical and curious tear into it. Sounds like the motor drive is working but the shutdown after you turn it off does not work. If it is like mine a park switch is linked mechanically to the back side of a drive gear in the wiper motor gear box. Remove the wiper motor assembly and put it on the healing bench. Open up the gearbox portion and figure out how it works. Almost sounds like the grease is a bit dry in the gearbox portion. You can test it without connecting to the wiper portion by just plugging in the electrical. The large nylon gear and park switch are replaceable in the wiper motor assembly I have.
Keep us posted on the ghost removal.................
Old December 20th, 2012, 10:14 AM
paluskat
Tom Paluska
D110 200TDI
thought I might have to get in there. Thanks for the suggestions.
motor
What makes the Rear Wiper park? COSteve Defender Technical Discussions 10 March 6th, 2007 04:40 PM
Rear Wiper - Anyone Please Kimos Defender Technical Discussions 14 November 8th, 2005 02:10 PM
Locating the rear wiper pepstein Defender Technical Discussions 0 April 2nd, 2005 09:56 AM
Wiper Blades going haywire... arbik Defender Technical Discussions 4 February 22nd, 2005 11:07 PM
bulkhead and wiper stud fitting problem mattdh Defender Technical Discussions 3 April 2nd, 2004 09:42 AM
