help with towing adaptor - Defender Source
Old March 25th, 2013, 06:23 PM
rcfarris's Avatar
rcfarris
Rory Farris
multiple
anybody aware of a 6 round to 4 flat adaptor for this monstrosity...00 td5
ID:	69000   Click image for larger version
Old March 25th, 2013, 06:30 PM
You may have better luck if you search for 7 to 4 as I do not count 6.
They're for sale all over the place on the Internet. This just so happened to pop up when I was looking.
http://www.defendersource.com/forum/...ad.php?t=43583
Old March 25th, 2013, 06:31 PM
Thats a euro 7 pin. Eric @ Atlantic British and Rovers North both sell them.
Old March 25th, 2013, 06:33 PM
rcfarris's Avatar
rcfarris
Rory Farris
multiple
thanks. never said i could count. i am from alabama
Old March 25th, 2013, 07:33 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
Converting to 4 flat ???
Hey Rory:
If you're converting to a 4 flat plug, you'll need a trailer wiring converter...
So your 7 pin has wires for separate brake lights, tail lights, L flasher, and R flasher.
The 4 pin gives you tail lights, and combines the brake light and flasher into one.
So you end up with a wire for:
both tail lights
R flasher and brake light combined
L flasher and brake light combined
The trailer wiring converter electronically overrides the brake light with the turn signal pulse. So when you are driving and step on the brakes with the flashers off, both brake lights come on (glow). But, when you have a flasher on and step on the brake, the brake light does not interfere with the flasher, since they both use the same bright element in the bulb. In this case the flasher will continue flashing and the opposite brake light will be the only one of the 2 brake lights glowing. Pretty simple really.
Hope this helps.
RDavisinVA
wing
towing with a D-90 gofins Defender Technical Discussions 9 October 20th, 2005 11:53 AM
Towing your D-90 tron Defender Technical Discussions 2 August 17th, 2005 01:40 PM
steering wheel adaptor Hollywood Defender Technical Discussions 7 August 16th, 2005 11:37 PM
Towing a D-90 - Do I need a flatbed? arbik Defender Technical Discussions 4 January 27th, 2005 12:33 PM
D110 Diesel conversion, towing. Kerr Defender Technical Discussions 3 May 5th, 2004 06:26 PM
