help with stalling issue, - Defender Source
Old November 29th, 2013, 04:34 PM
CavemanDiesel's Avatar
CavemanDiesel
Eric Smirh
1985 D90
I was riding along with a smile on my face. I came to a curve in the road, after the curve the Rover started to lose power, it still ran, but not very well, I drove for about 2 miles and came to stop sign and it stalled. I was able to restart it and get home. I think it's a fuel problem, just don't know where to start looking, oh yea, it's a 300 tdi,
What do you think?
Old November 29th, 2013, 04:39 PM
Originally Posted by CavemanDiesel View Post
I was riding along with a smile on my face. I came to a curve in the road, after the curve the Rover started to lose power, it still ran, but not very well, I drove for about 2 miles and came to stop sign and it stalled. I was able to restart it and get home. I think it's a fuel problem, just don't know where to start looking, oh yea, it's a 300 tdi, What do you think?
Fuel filter first.
Old November 29th, 2013, 04:44 PM
navydevildoc's Avatar
navydevildoc
Neill Thornton
Fuel filter first.
This. Drain the bottom if you can as well, you may have water all in it.
Old November 29th, 2013, 06:30 PM
How low was the tank on fuel?
I would disconnect the inlet line from the injection pump, remove the fuel solenoid wire and crank it over. See if you are getting a good flow of fuel from the lift pump. The pump could be dead or the filter plugged.
Old November 29th, 2013, 10:22 PM
CavemanDiesel
Eric Smirh
1985 D90
Over 1/2 tank of fuel.
Thanks for the advice, I will try tomorrow,
Old November 30th, 2013, 10:54 AM
CavemanDiesel
Eric Smirh
1985 D90
Ok, checked the fuel filter, there was some water and crud in it. What to good ahead abd replace it. Can I find one locally or do I need to order.
Strange stalling issue. Captain Spalding Defender Technical Discussions 4 September 9th, 2009 11:55 AM
stalling issue justinaldi Defender Technical Discussions 7 August 5th, 2008 01:59 PM
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
Stalling RR? headdamage Defender Technical Discussions 5 March 20th, 2005 12:29 AM
