Help with rear door - Defender Source
Old March 17th, 2008, 04:14 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
94 D90 Alpine White #1245
Help with rear door
I have to lift the rear door in order to shut it. I took a few pictures to see what I'm refering to. The two bolts on the hinge itself are really rusted, and I can't move them at all. What should I do?
ID:	12656   Click image for larger version
ID:	12658   Click image for larger version
ID:	12660   Click image for larger version
Old March 17th, 2008, 04:29 PM
Just don't open the rear door... :-)
I would put PB Blaster on the screws for the next few days then change out the screws with stainless ones.
Old March 17th, 2008, 04:58 PM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Change out the rusted parts and replace the hinge pins. Looking at the margins around the door the hinge pins may be worn out. Adjust the strike as needed.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old March 17th, 2008, 08:33 PM
Grover's Avatar
Grover
the brass balls are worn...replace them and you should be good to go...
Old March 17th, 2008, 08:54 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
Awesome!!! Thank you guys so much for all of your help! I love this D90 forum/Community, it's great how fast you get help, and the amount of knowledge this board has is incredible.
Does anyone know where I can get the brass balls, and maybe a part number too?
Kenny
Old March 17th, 2008, 11:59 PM
They come in a rebuild kit, for less than 10 bucks. I can't find a part number for them right now, but any Rover parts place will have them.
Old March 18th, 2008, 12:54 AM
bstraw's Avatar
bstraw
Byron Straw
1994 POE/ST
I think this is it. http://www.roverparts.com/Parts/5509.cfm I am sure you can find them from the other vendors as well. These are for the series but I used them on my door (95 d90) and they where the same ones. Hope this helps
Old March 18th, 2008, 01:00 AM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
george at rds has them
Old March 18th, 2008, 01:03 AM
Thats it - I dont know why the search function at AB is such complete crap. It almost never gives you what you want, and a whole lot of what you dont.
Old March 19th, 2008, 12:33 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Kenny, if you have time it would be great if you took a few pix as you did this project and posted your journey. I'd love to see what the overall difference turns out to be. I too see this problem starting on my SW rear door and will need to make the same upgrade someday i bet.
Clay
Old March 19th, 2008, 12:56 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
Talking
Clay
I ordered this part yesterday: http://www.roverparts.com/Parts/5509.cfm I hope this works. I will gladly take pictures of the rear door and hinges when I replace them, hopefully next week.
Thanks everyone for your help.
Kenny
Old March 19th, 2008, 01:44 PM
I hope you got two kits.
Ron
Old March 19th, 2008, 01:56 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
Smile
Ron
Yes, I ordered two kits
Old March 19th, 2008, 02:26 PM
cellulararrest's Avatar
cellulararrest
Chris Snyder
1994 D90 #614 | '07 L322 SC
While you're working on it, replace those bolts with stainless! You'll love it.
Old March 19th, 2008, 02:33 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
You know, I'm thinking of replacing all bolts with stainless. Where is the best and the cheapest place to order a kit from? I haven't seen a kit that has the rear cross-member bolts either. let me know
Kenny
Old March 19th, 2008, 08:35 PM
themaxx's Avatar
themaxx
Ade
94 ST
Kenny
It looks as if Andrew is sold out, but I'd still PM him anyways. JimC has been known to put a group buy together from time to time...
If all else fails use this pdf that Jim put together and order what you need from McMaster.
Good luck!
Old March 19th, 2008, 09:14 PM
kennybahr's Avatar
kennybahr
Kenny Bahr
Talking
Good luck!
Awesome...
Old March 19th, 2008, 11:00 PM
cellulararrest
Chris Snyder
I grabbed one of JimC's kits a little while back and he included rear crossmember bolts. Great kit. Very well put together.
Old March 20th, 2008, 01:45 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Yeah, I just sold the last of them. If I have a few people interested I can put a few more together. Mine included everything even the tire carrier, bonnet and captive nuts for the bulkhead. If people are interested PM me and I'll put a few more together. I just don't want to sit on a bunch of kits.
Old March 21st, 2008, 10:30 AM
kennybahr's Avatar
kennybahr
Kenny Bahr
Follow up post
I replaced the hing bolts and brass balls with the parts from Atlantic British. However, it did not solve my problem. The door is still uneven when it closes. I ended up moving the hinges that are bolted on to the door, but it is very hard to align them so the door closes. I finally ended up managing to open and close the door with no problem, but it just isn't as even as it should be. I'm also not sure how the brass ball, spring and bolts are supposed to work...can anyone inform me?
I also ended up snapping a few bolts while I was doing this project. The door striker on the truck, there are two bolts, I snapped one M88. I also snapped two of the bolts on the door striker itself on the rear door, the have phillips head tops. Can I replace these bolts with stainless steel, or anything I can get from Lowes or Home Depot. Let me know
Thanks in advance for any help
Kenny
ps I'll post pictures later.
door, rear door
97 D90 SW - Inner rear door panel Kimos Wanted 5 December 2nd, 2004 09:26 AM
Rear door inner panel Kimos Defender Technical Discussions 4 October 15th, 2004 12:57 PM
Need rear SW door Chris Cox Wanted 0 August 21st, 2004 04:11 PM
SW Rear Door Rattle seattlejanzen Defender Technical Discussions 5 November 5th, 2003 10:25 AM
