Help With Part ID - Thermo Housing/Coolant Temp Sensor? - Defender Source
Old March 25th, 2013, 09:50 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
This shade tree mechanic is appealing for some help in identifying the circled compenents in the pics below. I'm in the process of replacing my radiator and will also swap out the hoses and thermostat at the same time.
In the first pic, is the this the thermostat housing? Is it a straight bolt off and on for the thermo replacement? I have a new t-stat and gasket at the ready.
In the second pic, what is this component and should there be a plug attached to it?
Thanks.
ID:	68968   Click image for larger version
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 25th, 2013, 09:57 AM
Yes and the sensor is for the AC which I don't think you have. It basically allows the AC to shut down as a precaution if the engine is running too hot.
Thermostat replacement is straightforward although if you haven't changed the 2 small front hoses I'd do that as well while you are in there.
Old March 25th, 2013, 10:18 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Thanks Jason. So, where is the coolant temp sensor located?
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 25th, 2013, 10:28 AM
The Dro
Dro
1988 Ninety
That's the water (coolant) temperature switch.
Old March 25th, 2013, 10:50 AM
it a smaller sensor with a single wire in the block ... not far away.
Old March 25th, 2013, 10:51 AM
The Dro
Dro
1988 Ninety
Jason... The coolant temp sensor in the the thermostat housing.
I'll dig it up in RAVE.
Old March 25th, 2013, 10:52 AM
the sensor above the one you circled is the fuel temp sensor just in case you were wondering
Old March 25th, 2013, 10:59 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Good to know, thanks.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 25th, 2013, 11:03 AM
The Dro
Dro
1988 Ninety
Found it...
Old March 25th, 2013, 12:20 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Great info, thanks. I need to step up my game and get rave.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 25th, 2013, 12:32 PM
The Dro
Dro
1988 Ninety
PM sent
Old March 25th, 2013, 12:43 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
The Man!
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old March 25th, 2013, 02:36 PM
The Man!
Busy day at the office?
Old April 2nd, 2013, 10:24 AM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
I located the coolant temp sensor and ordered replacement part PRC2506. Mysteriously, the sensor that came out of my engine is diffeent from the stock part, which doesn't fit. The probe on the PRC2506 is fatter than the hole in the block.
Here are some pics of the old and new sensor and the mounting location on the block.
Has anyone seen this before? Any suggestions on the correct sensor part number?
The engine is a stock 3.9 and the gauge is the original, as far as I can tell.
ID:	69440   Click image for larger version
ID:	69442   Click image for larger version
1997 P38 4.6
1998 P38 4.0
2011 LR4
coolant, part, sensor
300Tdi locating coolant temp sensor? crown14 Defender Technical Discussions 10 February 22nd, 2017 05:10 PM
Temp Sensor Values - I'm Not Sure if its Overheating! Stmpede Defender Technical Discussions 2 April 5th, 2012 01:11 PM
4.0 Temp sensor Size 97-D90-736 Defender Technical Discussions 2 December 31st, 2010 12:26 AM
Erratic Oil and Temp Sensor Jon_Winningham Defender Technical Discussions 10 March 30th, 2007 09:27 PM
fuel temp sensor mattdh Defender Technical Discussions 2 May 13th, 2006 08:59 PM
