help with odometer issues - Defender Source
Old April 15th, 2014, 09:02 PM
anuctoo
Brad Casteel
2006 LR3, 1994 D90
how big of an issue is an odometer that's been replaced? I'm thinking of replacing my d90 that i sold but both the ones i'm looking at buying have odometers that have either been replaced or reported as an issue. that pretty much kills the resale value doesn't it?
Old April 15th, 2014, 09:09 PM
NPT90's Avatar
NPT90
JT
D90 óriginalé
A d90? ROW? I mean I don't think you're kidding anyone with a 0 mileage 25 year old car
Old April 15th, 2014, 09:15 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
what does the car fax say?
yes it will hurt value now and in the future
good luck with your search
Old April 15th, 2014, 09:25 PM
anuctoo
Brad Casteel
2006 LR3, 1994 D90
one has a branded title for not actual miles and the other one is at a dealer who replaced the odometer but is exempt from odometer reporting per the car fax.
Old April 15th, 2014, 09:43 PM
the whole true miles unknown thing and dealers saying it's not a big deal that the odometer was replaced (without documentation) because the vehicle was exempt is total BS…especially when they often try to sell the truck for the "low miles" that only the odometer shows. Is the true miles unknown truck yellow per chance and shows roughly 40,000 miles?
Old April 15th, 2014, 09:48 PM
anuctoo
Brad Casteel
2006 LR3, 1994 D90
One is yellow with 55k on the odo but branded title. The other is white.
Old April 17th, 2014, 01:51 AM
scottsdaleaz
Jared
D
I personally would not purchase a truck with any odometer issues. You are only limiting your pool of buyers if/when you decide to sell it yourself. If you are questioning it now, imagine the others that will question it when you sell it.
Old April 17th, 2014, 02:09 AM
A high percentage of 97s had the odometer blank out and a decent number of 94/95 had the odo stop at 100k.
Ignoring these trucks really limits you. I would be fine with one as long as actual approx miles was documented. ie odo replaced at x miles.
Old April 17th, 2014, 05:52 AM
anuctoo
Brad Casteel
2006 LR3, 1994 D90
Thanks for the advice!
Old April 17th, 2014, 07:35 AM
Like the curmudgeon suggested pull a carfax. The reason the speedo's were replaced was because the odometer stopped working, nothing shady about it and no other choice but to replace or remove and send off to hollywood speedo and have original repaired. Car fax should show/give some idea of the mileage before a swap was made. What I typically do is put the old gauge and new side by side on a piece of paper with the date on it and take a picture. That documents the date the swap was made and the mileage the old gauge died @.
Old April 17th, 2014, 08:00 AM
What you perceive as the condition of the vehicle based on your inspection is probably a truer assessment than the odometer or carfax.
Just because it says 55k on a 20 year old vehicle, could easily mean it was put away 10 years ago and has all seized up.
Lashcap issues/valve cap issues trybul Defender Technical Discussions 6 January 9th, 2012 12:46 PM
Need Help: Odometer Question WCURoverD90 Defender Technical Discussions 6 August 5th, 2005 07:41 PM
odometer led out..replacement cost? tomken Defender Technical Discussions 1 December 21st, 2003 10:27 PM
Odometer problem 97 jorge Defender Technical Discussions 3 November 19th, 2003 01:13 AM
Odometer/speedo correct? sherpamike Defender Technical Discussions 2 October 15th, 2003 08:52 AM
