Help with engine not starting - Defender Source
Old April 4th, 2005, 11:26 PM
cbass's Avatar
cbass
Bradlee Duncan
'94 White and '95 Red D's
hey guys,
As some of you know, our D-90 was wrecked. Well, we decided to buy it back from insurance and fix it ourselves. I was working on it tonight and what I am planning on doing is to get the engine and transmission ready to be stored for a while because I won't be running them much during the frame replacement (which will be an extended project due to time constraints). Here's a little background on the wreck along with some pics for those that haven't seen it yet... http://www.defendersource.com/forum/...=advice+sought
So I went to try and start the engine today because visually, nothing happened to it. I just wanted it to catch so I could be sure that it was OK. It would turn over, but wouldn't catch and I couldn't figure out what the problem was. The spark plugs are sparking, so I am pretty sure the problem lies in the fuel lines. it really doesn't sound like it's getting fuel. I checked all the fuel lines visually and they are all fine though. I know the fuel tank was emptied by the shop that was looking it over for insurance. I only had about 2 gallons of fuel at home, so that's all I put in. It still wouldn't catch when I tried starting it.
Does anybody have any suggestions as to what may be the problem? Or a way that I could narrow it down??
After I know that it will at least start, I can go ahead and store it (i.e. fogging oil in the cylinders, anti-sieze on the spark plugs, block intake/exhaust holes so critters don't move in, etc.) I really want to get it started though first. BTW, it has been sitting for about a month outside on the body shop's lot. It was never started there though FWIW.
If I put a socket on the crankshaft bolt, the engine turns over freely also.
Any suggestions to get it started???
TIA!!
Old April 5th, 2005, 12:23 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
IIRC, there is a collision sensor somewhere in there and cuts power to the fuel pump if it's tripped.
-Hans
My oil line fix
My 100k stopped odometer fix
Old April 5th, 2005, 12:54 AM
inertia switch
Old April 5th, 2005, 06:25 AM
Yep sounds like the inertia switch. It should be in the fuse pannel, about the size of a relay with a button on top.
Old April 5th, 2005, 12:12 PM
cbass's Avatar
cbass
Bradlee Duncan
That worked!!! Fired right up on the first crank of the key. Thanks for the help guys!!!
engine, start, starting
Engine Proble: Please Advise saber6 Defender Technical Discussions 24 November 6th, 2009 10:06 AM
Not starting '95 what to check next. jcasteel Defender Technical Discussions 17 June 10th, 2005 02:38 PM
???still can't get the trany unbolted from the engine???? kit Defender Technical Discussions 4 October 23rd, 2003 03:20 PM
