Help with electrical issues - Defender Source
Old October 3rd, 2015, 03:44 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I have two issues I'm trying to work through. Disclaimer, I am REALLY bad with electrical stuff so I'd appreciate any help.
1.
I have a parasitic draw on the car. Very small, kills the battery in about 2-3 weeks. Battery is still good so I performed an amp test by bridging the negative cable and negative terminal. At rest, the car is drawing .40 amps. I went and started pulling fuses to see the effect would be:
top left fuse, the one the clock is on- 6 MA
Hazards- 24MA
I stopped at the hazards as that brought me down to .16-.18 amps. Is 24 milliamps normal for the hazard circuit while it's off? That seemed wrong to me. I do have LEDs if that matters
2.
I have a Hella 3000s across the roof. inner two and outer two are on separate switches. Inside two stopped working. I took the volt meter and went down the wire. At the fuse, with the switch on, it's reading roughly 8.5 Volts. Next I went to the relay, pulled that and bridged that I think is the 12V and ground and got 8.5 volts. So if power is getting to the relay but no lights, I can assume it's the relay that needs replacing correct? It's a 12V 30amp relay. Do I need a Hella specific one or can I get any relay that matches 12v and 30amp? It's Hella part # 4KA 003 510-08. I can't find it online so i'm hoping any old relay from the auto store will work.
electrical
Electrical Issues bossman429 Defender Technical Discussions 3 October 6th, 2011 10:25 AM
Electrical Issues & the best repair manuals for a 1995 D90 agavelvr Defender Technical Discussions 18 August 23rd, 2011 12:54 PM
Experiencing wierd electrical problems, engine power issues? madcowdungbeetle Defender Technical Discussions 0 May 26th, 2008 10:14 PM
battery/ electrical issues steve_brooks Defender Technical Discussions 1 April 23rd, 2004 04:05 PM
Electrical relay issues???? PMHAH Defender Technical Discussions 1 November 20th, 2003 02:32 PM
