Help With Electrical Gremilins - Defender Source
Old January 5th, 2006, 07:59 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I did a search but the topic is sort of obscure and has only been touched upon. I have a few accesories like a stereo, 300 watt amp, XM sat, fog lights and then the stock electrical components. When I am using too many things at once ( like XM, stereo, amp, and either high beams or heater fan) my tachometer stops working. I just replaced the alternator when it quit and I have a (hold the criticizm) Optima yellow top battery. I seem to be drawing too much juice for the alternator when running too many accesories. One other thing, the XM radio is the one thing that really seems to do me in. When it isn't on then I don't think that I have any problems. So do I need a stronger alternator or do I have a short or bad connection through the XM radio mount?
Any help would be appreciated.
Old January 5th, 2006, 08:07 PM
XM should use 3 amps or less. Sounds like a bad connection or a bad power supply in the unit.
Old January 5th, 2006, 09:18 PM
robisonservice
John Robison
2008 Supercharged Range Rover
If the tach stops working it probably means the alternator is cutting out. Either the alternator is bad or you have wiring troubles - corrosion, bad grounds, etc.
Old January 5th, 2006, 09:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
How is the XM wired in? Where is it drawing its power from? I have mine feeding from the same switched power as the radio and never had a problem.
Also, the stock tach kinda sucks. Mine was all over the place for a while after I changed my coolant gauge. The wiring and connectors are real sensitive to any changes and like to fail.
How is the connections on both sides of the battery cables?
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 6th, 2006, 03:40 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
check your main earth lead from the battery
Old January 6th, 2006, 05:01 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Battery Terminals are good (clean), battery ground is solid (to the frame), XM is powered to the radio 15amp fuse. I have paid more attention to the problem which seems to be coming from the high beams. When I turn them on the tach immediately drops about 500rpm's or quits all together. I am starting to suspect the alternator. What do you guys think?
If it is the alt. then do I need a higher output one? 120 or 200 amp? or is the stock one sufficient?
Old January 6th, 2006, 05:20 PM
ne4x4's Avatar
ne4x4
Ian McCormack
1984 Landrover 90
Check the high beam circuit for a short or dodgy earth connection there has to be a short or similar to cause that sort of problem
Old January 6th, 2006, 06:32 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I had another thought. Could my Hella H4 headlights be the problem? Could they be drawing too much juice?
Old January 7th, 2006, 01:24 AM
Hans's Avatar
Hans
Hans Haase
Which bulbs do you have in them? Very strong possibility, as the headlight system draws all the power from the switch. It's highly recommended that you use relays and run the power for the headlights back to an independant source, especially if you upped the wattage at all, or you risk melting the entire headlight switch over time.
-Hans
My oil line fix
electrical
Tdi electrical diagram artm Defender Technical Discussions 2 January 13th, 2006 08:52 PM
Electrical problem whistler110 Defender Technical Discussions 10 December 12th, 2004 12:25 PM
Electrical for beginners paulb Defender Technical Discussions 5 October 18th, 2004 01:58 PM
battery/ electrical issues steve_brooks Defender Technical Discussions 1 April 23rd, 2004 04:05 PM
on-going electrical problem... vesparover Defender Technical Discussions 3 October 23rd, 2003 11:13 AM
