HELP with door ajar sounds and light - Defender Source
Old May 17th, 2008, 09:18 AM
kennybahr's Avatar
kennybahr
Kenny Bahr
94 D90 Alpine White #1245
I think I blew a fuse somewhere along the line. When I would leave the key in the ignition, or the lights on, there would be a door ajar sound, it doesn't do that anymore. The overhead light used to go on when a door would open, however it doesn't work anymore. The passenger door opens and the light goes on, the driver door does not. Is this a fuse problem, or a wiring issue? Thanks
Kenny
Old May 19th, 2008, 05:41 PM
jimngo's Avatar
jimngo
Jim Ngo
1994 D90 #80
It's probably a switch issue. Pull out the switches and clean them with some sand paper and contact cleaner. Reassemble with a dob of some electrical grease or vaseline to slow down the future corrosion.
door, ht
1994 Yellow NAS D90 - Canadian Truck FS DonFromWhitby For Sale - Vehicles 1 November 16th, 2009 03:24 PM
Oil Light When downhill braking Baldewin Defender Technical Discussions 6 September 20th, 2006 10:04 AM
brake light switch snuffer Defender Technical Discussions 7 March 28th, 2006 07:02 AM
ECU readout cbass Defender Technical Discussions 15 September 17th, 2005 10:05 PM
Moving Dim Lights.... Eric Siepmann Defender Technical Discussions 3 November 22nd, 2004 11:46 AM
