Help with Defender 90 Blinkers and brake lights - Defender Source
Old May 15th, 2017, 03:19 PM
ViperJames
James Forte
1991 Defender 90
Hello I am trying to diagnose my 1991 Defender 90 electrical issues..i just bought the car and seller only had car a short while so had no idea of the issues... There was definitely aftermarket stuff added to car like winch on front, roll bar with lights rear trailer connection, etc. Looks like some stuff i just "unplugged" trying to follow a wiring diagram to me is not simple if i could see actual photos of wiring that is CORRECT it would be helpful but perhaps someone can tell me by looking at what i have here in the dash area if it just looks like things are not connected or if i have a major issue. Thanks! James
ID:	244674   Click image for larger version
Old May 15th, 2017, 03:20 PM
ViperJames
James Forte
1991 Defender 90
Also The rear wiring i can take photos in a couple hours to post looks like MAYBE some things got disconnected but again i am not positive. I have always done most of my restoration work but electrical has not been my strong suit, however it seems like a Defender would be very easy to learn on so i am actually happy to have the experience with this. Thanks
Old May 15th, 2017, 03:22 PM
Most of that disconnected stuff is not original wiring. You will need to follow the schematic and understand electrics to figure it out.
Old May 15th, 2017, 03:24 PM
ViperJames
James Forte
1991 Defender 90
Thank you. i have a detailed work manual on its way here, just thought some Actual photos of what it SHOULD look like would be helpful for me understanding. thanks
Old May 15th, 2017, 03:29 PM
The problem is you center dash area is missing all the things that should be there. Most stuff plugged into that area would be there to plug into.... The flasher system parts are in the steering column and the fuse panel. It is pretty simple and standard.
You can download manuals here: pdf Land Rover Manuals | Landroverweb.com
The bigger problem is that the photos show that a previous owner has seriously messed with the electrical and that is never a good thing.
Old May 15th, 2017, 03:39 PM
ViperJames
James Forte
1991 Defender 90
Really APPRECIATE THE HELP! THANK YOU!
Old May 15th, 2017, 06:12 PM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
on the first picture the wires to the left are factory. The factory put a bunch of wires there to connect other stuff like the radio etc. As mentioned above the other wires look aftermarket. Follow the wiring diagram and you can start to isolate the factory wires. The aftermarket stuff...you just have to trace them to where they go.
Land Rover 110
Old May 19th, 2017, 08:27 AM
ViperJames
James Forte
1991 Defender 90
Update! Okay so I have made some serious progress...turns out the issue was not so bad, the Right Rear blinker was missing when i bought vehicle and it appears the wires were fried somehow and in turn fried the flasher. I replaced all the lights with LED's and replaced the flasher, all blinkers work except the right rear. Question is how far back do i replace the wire?
Also the reverse/ rear fog lights, have a black/ red wire on the new LED, and the old wire is Blue and Brown...which goes where?
Thank you!!
Old May 19th, 2017, 10:09 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Thank you!!
Blue should be your positive/live and brown is your ground.
I don't think it matters how far back you make the splice, so long as the wire is clean to work with. Suggest getting some water-tight shrink tubing (adhesive lined) at the splice to prevent future water intrusion and corrosion.
Old May 19th, 2017, 10:12 AM
ViperJames
James Forte
1991 Defender 90
You are the man Chris! THANK YOU!!!!
90, brake, defender, defender 90, ht, lights
top warning/indicator lights not working draaronr Defender Technical Discussions 2 May 22nd, 2008 06:43 PM
Lights, Blinkers, and Everything Electrical WestTexasDefender Defender Technical Discussions 3 April 20th, 2006 10:21 PM
