Help with clutch recommendation - Defender Source
Old April 10th, 2012, 09:28 AM
nwp's Avatar
nwp
Nathan Patterson
1994 D-90
I need to get a new clutch for my 1994 NAS D90. It has a 3.9 liter with the stock R380. I'd like to get something a little more heavy duty but I'm having trouble finding a "stage 2" clutch. Any advice would be most appreciated. So what do you guys think?
Old April 10th, 2012, 09:40 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
Call George @ RDS
Old April 10th, 2012, 10:55 AM
nwp's Avatar
nwp
Nathan Patterson
1994 D-90
Thank you. I left him a message. Justin at Lucky 8 has the standard replacement. Does anybody have experience with non OEM clutches?
Old April 10th, 2012, 08:55 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
Just came across this while searching myself for a clutch http://www.andysautosport.com/land_r...tch_kits/spec/
Pricey
Old April 10th, 2012, 09:33 PM
Dude ... Don't mess about with non-standard clutch ... Heavy duty means heavier action, stronger pressure plates and crappier gear change ... Added to that they are probably less reliable than standard because they make less of them.
go standard ... Go for what's common ... Go genuine if you can or a popular patttern part if it's too expensive.
Old April 10th, 2012, 09:37 PM
grnrvrs's Avatar
grnrvrs
Paul
88
What are you trying to accomplish with a "heavy duty" clutch? Greater longevity? More clamping force? Are you uprating your power plant? Or, it is just that your current clutch is shagged?
1970 SIIA 88, Sold
Old April 10th, 2012, 09:40 PM
How do you objectively quantify a HD clutch v normal duty unit? Reliably?
Old April 10th, 2012, 09:42 PM
grnrvrs's Avatar
grnrvrs
Paul
88
Clamping force.
1970 SIIA 88, Sold
Old April 10th, 2012, 09:55 PM
That does not neccesarily equate with longevity
Old April 10th, 2012, 10:03 PM
Mpigapicha's Avatar
Mpigapicha
phil
1995 Defender D90
I don't have any issues with mine, just figure since in its bowels removing gearbox, might as well replace.....
Old April 11th, 2012, 01:44 AM
grnrvrs's Avatar
grnrvrs
Paul
88
Agreed, hence my question to the op about his intended purpose.
1970 SIIA 88, Sold
Old April 11th, 2012, 09:31 AM
Antichrist's Avatar
Antichrist
Tom Rowe
Defender/Disco/Series/MoD
Last clutch I got from DAP. Don't remember the brand, but it's been good for the last 100k miles.
Tom Rowe
Atlanta, GA
62 88 Regular
67 109 6cyl NADA x2
95 DI 5-speed
95 D90 5-speed
97 D1 Automatic
Old April 11th, 2012, 02:22 PM
Borg and beck makes a nice clutch. If driven humanely, a defender V8 clutch should last 250k. I replaced mine recently and the mechanic said it looks pretty new at 12Xk.
Old April 11th, 2012, 02:56 PM
nwp's Avatar
nwp
Nathan Patterson
1994 D-90
I ended up going with a stock type Borg and Beck from George at RDS. I looked at the options on AndysAutoSport as well.
I have a stock 3.9L motor but have been considering upgrading. Still not sold on other power plants though. I have looked at RPI and JRE. Your collective thoughts would be appreciated on that as well. Thank you guys for the information. I actually feel better about my purchase now.
clutch
Chattering Clutch - Help R. Kurk Defender Technical Discussions 1 June 26th, 2009 05:33 PM
screaming clutch jimmy salmon Defender Technical Discussions 5 November 24th, 2007 12:32 PM
90 v8 clutch problem robheath Defender Technical Discussions 0 August 19th, 2004 06:45 PM
