Help with clutch master pipe routing 4cyl LHD 1984 90 - Defender Source
Old May 11th, 2011, 12:12 PM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Grrr arg..
Purchased part number NRC8329, it arrived and I cannot see a way to get the pipe to route to the proper location.
I think they sent the wrong part but wanted to check with others and see if they can confirm if it looks like the proper part and maybe post a few pictures of how the pipe routes.
Old May 13th, 2011, 08:19 PM
16kpsi's Avatar
16kpsi
Tony Lawson
1986 D110 ex-200tdi to be 6BT
hmmm. Mine does not look like- but I ordered the same part number you list when I got mine from RN(can't believe I just found the receipt!). I have a 1992 with a 1984 Master. I put in a new pipe when I converted to LHD.
The left half of your pipe kinda looks like mine. The high loop goes up near the bulkhead under the steering column just where it exits the bulkhead. On mine, the right side goes diagonal from the upper, middle bend to the fitting that turns hard into my master cylinder (instead of coming way down in a square loop as your does)
BTW: the fun I discovered - I could not get the pipe in unless I removed the brake box (again). Could not find a way to snake the pipe under the steering column without destroying it. Maybe there's a trick, but I couldn't figure it out.
ID:	38687   Click image for larger version
Old May 14th, 2011, 10:35 AM
dave_lucas's Avatar
dave_lucas
Dave Lucas
Thanks for posting the pics, I had no idea it would go under the steering and behind the master. You just saved me countless hours of beating my head against a wall
I sent an email to the company and they claim that they sent me the correct part and that they had to bend it some to get it in the box. It looks like maybe they made the bends into 90's so I will try slowly un bending them and maybe I can make it work.
1984, 90, clutch, lhd, master
Clutch master cylinder replacement Trigger Defender Technical Discussions 20 July 8th, 2015 08:01 PM
Clutch Master Cylinder Billakris Defender Technical Discussions 22 November 29th, 2011 03:02 PM
Brake pipe part number help for early LHD 90 dave_lucas Defender Technical Discussions 6 April 30th, 2011 05:00 PM
NEW Clutch Master Cylinder 4 Sale roverboy For Sale - Parts 0 October 6th, 2004 10:10 PM
