Help With Alternator for a 97 - Defender Source
Old March 19th, 2005, 02:48 PM
UpnOver's Avatar
UpnOver
David Williams
'97 Yellow ST
My alternator is on it downward spiral. I have check through past post, but didnt find what I am looking for. For all you '97, what alternator are you using, factory or aftermarket? I saw rover connection has a 120 amp for $295, mean green 200 amp for $375. Which one is best one to get? What the difference, do I need the more amps? Is the MG a direct bolt replacement? Whats the best place to get new one from? I am up for any suggestion or comments.
David
Old March 19th, 2005, 02:51 PM
I tried going down the Mean Green road a bit but got fed up with there customer service and needed an alt quick, so I got mine at the local autoparts store, It wasn't too exspensive but I have not used it at all yet (my truck is still broke from last year). But it looks good!
Old March 20th, 2005, 11:38 AM
48vphantom's Avatar
48vphantom
Jeff Hoien
1997 NAS D90
David, here's what i did. Found a reputable electric shop that knows magnetti marelli(sp) alternators and had it rebuilt. Assuming the stator is still ok(not burnt) the only parts to be replaced are bearings, diodes, regulator and brushes...one day job and $150 bucks...
jeff
Old March 20th, 2005, 01:21 PM
NashvilleRedD90's Avatar
NashvilleRedD90
Will Peters
'97 NAS D90 ST #1704 -4.6
I had my alternator rebuilt about two years ago on my 97 by a local shop for $100 and I have not had any problems with it since. I would avoid Mean Green alternators; I used one for a wile and was not happy with it. For the price you can find something better.
'97 D90 - 4.6
'00 D2
Old March 20th, 2005, 02:23 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
I have had nothing but joy from my mean green alternator. Been about a year and works perfectly.
Old March 20th, 2005, 09:43 PM
Eric Siepmann
Eric W. Siepmann
1997 Defender 90 SW
Bosch Rebuilt. No troubles yet. Knock on Wood.
EwS
97, alternator
97 Gas pedal questions shawnpalmer Defender Technical Discussions 3 May 5th, 2009 05:19 PM
R380 in an NAS 97 D90 Conversion? GYM Defender Technical Discussions 19 November 5th, 2008 07:21 PM
97 D-90 ST B-pillar rayfi Wanted 0 November 5th, 2008 12:56 AM
Wtb 97 D90 ECR Wanted 6 September 12th, 2008 08:50 PM
help / opinons on 97' ST januconn92 Misc. Chit-Chat 1 January 12th, 2004 12:16 PM
