Help with AC retrofit - Defender Source
Old March 1st, 2012, 06:04 PM
red&yellowrovers's Avatar
red&yellowrovers
Joe Still
95 D90 NAS 3.9l ST AA Yellow #2719
So I bought a "94 D90 AC" to retro fit to my 95 D90 NAS. I heard it referred to in the sales conversation as the Wynns unit.
My parts book shows a completley different unit for 95 and shows the Wynns unit for the 97. The shop manual is a waste of electrons in terms of graphic depcitions.
Can someone please share pictures of how the h### it goes in? I'd assumed it replaced the old heater box under the hood but I don't see a connection for hot water to the Wynns- just refrigerant. Also the shapes could hardly be more different.
Help appreciated! js
Old March 2nd, 2012, 08:38 PM
So i put a 94 AC in a 95 ... it's probably a worth having a conversation .. can you upload a set of pictures so I know exactly what parts you have ... the hardest part was figuring how to wire it in ... in the end it wasn't so tricky. send me a PM and I'll give you my phone number
Old March 3rd, 2012, 11:30 AM
red&yellowrovers
Joe Still
Was yours the Wynns unit?
Old March 3rd, 2012, 11:45 AM
Joe post up some photos.
Yours looks like this?
http://www.defendersource.com/forum/...ad.php?t=34436
Old March 3rd, 2012, 07:14 PM
Mine was the Davia .. I think ... it looks exactly the same as the unit in claimed wynns link josh posted ...
Does yours have a little square box with fuses / relays separate?
The material difference is that one will plug straight into your loom and the other will need to be adapted.
Post a picture and we let you know which route you'll have to take ... I can also let you know if the setup is complete ...
ac
Overheating with AC on nmc Defender Technical Discussions 9 July 28th, 2009 08:13 PM
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
D110 AC Repair Lesandjes Defender Technical Discussions 4 June 5th, 2008 12:55 PM
Air Conditioning Parts Question for 1995 D-90 Retrofit Heath Defender Technical Discussions 2 May 25th, 2005 02:54 PM
H4 retrofit lens/bulb combo = dim lights! jaherring Defender Technical Discussions 1 January 18th, 2005 12:37 PM
